Perhaps in a year or two I could trade in for a smaller tractor.
You could very well be the first in the history of TBN to trade down, or, at the very least, the first to admit doing so should that ever come to pass. Furthermore, if anyone successfully trades down and expresses their delight with such a decision, I anticipate an increase in work load for psychiatrists nation wide - and in Canada.
I second the vote to buy a
B3030. You'll appreciate the additional hp and the larger size of the rear implements that can be operated with its PTO. And, you can add a cab to the
B3030 at a later date which, in my view, is a wonderful option to have available should A/C or heat become desired comforts for longer periods in the tractor seat.
Based on your property and your project descriptions, I would also suggest that you rent a boxblade and a post hole digger. If you do not own an open trailer, I'd suggest that you direct the savings [rent vs purchase] toward the purchase of a 2-axle, open trailer. You can then transport rental items from and to the rental location, and you'll have the trailer for endless other uses.
For what it's worth, we had a tractor that was comparable to the
B2630 in size. We ran it constantly for 7+ years as we developed our acreage [nearest to the house]. It was fantastic to have. It seemed to be involved in every project. We finally sold that tractor because it was a 2WD model, and the further we ranged from the house, the more this limitation got exposed.
I offer this as a similar concern that you might encounter if you choose the smaller tractor as a one tractor solution. In our experience on our 15 acres, the obstacles and the projects get bigger as you range further from the house. And, that calls for more hp. In our case, it called for 4WD, but I also felt that our 25hp and FEL hydraulics were being taxed as we attempted to tackle larger obstacles.
Another consideration is a two tractor solution. It can be expensive, but it can also be done over time. Buy one and see how far it takes you.
You could start with a
BX24. My next door neighbor owns one. It is amazing. You'd get the full benefits of a TLB. The backhoe is a tool that you will never stop finding uses for. In fact, it will end your need for a post hole digger. The
BX24 will easily handle a lot of projects that you have on your list. If and when you find that the
BX24 is over matched, you can add an
L3400 or the
L4400. That will give you a powerful, second tractor to take on those bigger projects. The same attachments can be rented for the L-series tractor.
BTW, I also cut 3.5 +/- acres with a 42" Sears mower. The
BX24 offers a MMM that is larger. Most important, you can drive it three times as fast as the Sears mower. Your mowing needs will be solved.
Best of Luck!
The Gardener
