B3030 Floorboard Vibration
/ B3030 Floorboard Vibration #21
Killer_B said:
Yeah. I have fallen head over heals for a 3320. But I just can't easily let go of that sweeet Kubota quality. I do not think the JD's have it. If the B3030 was as smooth as my B7610, I would already have one. As it stands, I just can't see long term tractor happiness with numb feet. And I don't want a tractor with a mere 1.5 PTO HP more than my last one.
Killer_B. If you like the JD 3320, I would be comparing it to a GL3240 with a LA723 loader.
The B series tractors are real nice and one of their strengths IMHO is their weight (or lack of it) - great for finish mowing. Really nice mid mount mowers to boot. If you are comparing to a JD 3320 I don't think the GLs have much of a weight disadvantage to speak of compared to a JD3320.
You are correct. The JD seems to fall in the gap between the B and L series Kubota, but is probably better compared to the L’s.
I see it as kind of a papa bear, momma bear, and baby bear type thing. The L3240 is the papa bear, and it's just too big to be mowing my lawn with. The B3030 is the baby bear, and it would actually be just perfect for what I want to do. But, alas, I just couldn’t live with the vibes and rattles. I’m a little particular that way.
So I have settled for mamma bear, the JD 3320. It is compact enough to mow my yard with, and supremely comfortable. Yea, it's a little big compared to the B3030. But that's OK. Compromises must be made.
Now the hard part will be waiting 3 weeks for them to put this thing together. In the mean time, the old push mower (and the pushers) are getting a real work-out.
/ B3030 Floorboard Vibration #23
Killer B,
I too am considering upgrading my 7610 to a 7800 or 3030. Increased 3pt and pto HP, as well as increased stability (due to wider stance and longer wheelbase) and increased loader capacity. (more, more, more!)
I posted a question here some time ago about a 7800 update. Perhaps a 7810? No real answers then, but I guess some promise now. Guess we'll all have to wait until late Sept.
As far as the engine, I wish Kubota would put the 3 cyl 34 HP they use the the GL3400 in a B. I've heard that they are quite smooth. And larger at around 100 c.i.d.
/ B3030 Floorboard Vibration #24
hazmat said:
A tip for other owners, when you take the loader off, leave the pins with the loader - they rattle something fierce if you leave them on the tractor...
The FEL arms have a couple of nice "holsters" to drop them into for just this purpose, I'm not sure why anyone would be tempted to leave them on the tractor and possibly run the risk of losing one. Am I missing something?
WayneW said:
Killer B,
If that happens, I probably will wish I would have waited.
/ B3030 Floorboard Vibration #26
KillerB-
I have a B3030HSDC I bought about a year and a half ago, now have approx. 80 hrs on it. I have never felt any vibrations in the floor boards that really stand out. In fact after I read this thread the first time I had to go start mine up and use it to try to see if I could feel the vibrations. I only felt a very slight vibration, and that was when I was really trying hard to concentrate on feeling something on the floor boards. If I wasn't trying to feel it I would never know it was there. So I guess I got a good one! :confused:
I have heard that they send all the good tractors to the U.P. and we trolls get the rest ;-)
/ B3030 Floorboard Vibration #28
Killer_B said:
Good point. But at $20K+ a little refinement may not be an unreasonable expectation. Especially when the other makes (and other Kubotas) don't numb your extremities.
I can feel vibe's when I stand beside mine and put my hand on the floorboard...but none with my feet or my rump when sitting and operating mine!!
/ B3030 Floorboard Vibration #29
My B3030 does have some vibration at certain RPMs. Not noticeable in the floorboard, though. Mostly in the steering wheel, fenders and 3PTH arms. I have found the sweet spots ( Rpms with least vibration) to be: 1100 rpm idle-very smooth, 1600 rpm-smooth, 2100 rpm-pretty good, 2500 rpm- a little buzzy but not bad. These also happen to be the rpms that I do almost all of my work at. 1600 for plowing snow and light loader work. 2100 rpm for heavier, faster loader work, 2500-2600 for mowing. I also put a bungee cord on the loader control when the loader is off. It buzzes pretty good if not tied down. With the loader on it is not a problem. Overall, I am OK with the amount of vibration that it has. It could be better, though. Aside from that, I love everything else about it. It is an awesome tractor and suits my needs perfectly. I also looked at the 3*20 Deeres and decided that they were too big and too heavy for me. When my ground is wet in the spring the B3030 with loaded tires is on the heavy side for mowing lawn. That is why I kept my JD318. If the ground is too wet for the 'Bota, the old JD gets the job done with minimal impact on the turf. Slow compared to the B3030 and 60" MMM, but it works until things dry out.
/ B3030 Floorboard Vibration #30
What you read the manual?:eek: :D :eek:
When I took it off I said hmmm, where can I put these, put them back on the tractor, 2 minutes later said - this ain't working out and put them on the loader. I'll look for the holster next time...
/ B3030 Floorboard Vibration #31
Don't have one, but I think the "holsters" fit the small diameter handles, and not the body of the pin, so perhaps that is why you didn't notice them quickly. Think small diameter when you are looking....... :D
/ B3030 Floorboard Vibration #32
Actually they hold the big diameter... the small diameter cross pin is what keeps them from falling through. Not sure how you could miss them, they're just to the top inside of the boom arm, closest end to the tractor. I'll take a pic if it will help :D
/ B3030 Floorboard Vibration #34
Observe :D
/ B3030 Floorboard Vibration #35
Thanks DN - I actually found them on my own last night (now that I knew I should be looking for them).:rolleyes:
/ B3030 Floorboard Vibration #37
To answer Haz's original question, no I didn't get that from the manual :) Just out of curiosity I dug my manual out, and all it says under REMOVING THE LOADER is:
9. Remove the mounting pins from the loader main frame and hold them on boom.​
No illustration, questionable grammar. Indeed, they could've been a little more specific. I like that they're within easy reach w/o getting off the tractor.
/ B3030 Floorboard Vibration #38
ethiojazz said:
Is the 4 cyl more shaky than the three?? I just got a quote for a 3030 which was only 1000 more than the 2630. It seemed to make no sense to me until I read this thread. And if anyone had the old 2710 and 2910 could you comment if they also vibrated?? In trying out tractors I dont remember them being any more vibration thank my 2410.
I have a 2001 B2910 with about 950 hours on it, and I can confirm that there is a little vibration, but it's only noticeable if you are sitting still and concentrating on the vibration. Otherwise if you're doing something that requires your attention, It's not noticeable. Like others have said, the vibration is more pronounced at certain RPM's. I've used mine for up to 10 hours straight, and I've never had any part of my body go numb except my bum (from extended sitting, not vibration).:D
If I want to get a job done, I can always rely on my Kubota to outwork me every time. If I want to be comfortable, I'll go sit in my recliner with a beer in one hand and the remote in the other. :D
/ B3030 Floorboard Vibration #39
Thanks Bubba,,,
Spoke to a couple of dealers and they said the same.. Both with the 2710/2910 and the 7800...
2007 Toyota Tundra 4x4 Crew Cab Pickup Truck (A64556)
2007 Toyota Tundra...
FORD 5 BOTTOM PLOW (A64278)
FORD 5 BOTTOM PLOW...
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A64557)
2013 29ft. Larson...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
