B3030 Floorboard Vibration
   / B3030 Floorboard Vibration #31
Don't have one, but I think the "holsters" fit the small diameter handles, and not the body of the pin, so perhaps that is why you didn't notice them quickly. Think small diameter when you are looking....... :D
   / B3030 Floorboard Vibration #32
Actually they hold the big diameter... the small diameter cross pin is what keeps them from falling through. Not sure how you could miss them, they're just to the top inside of the boom arm, closest end to the tractor. I'll take a pic if it will help :D
   / B3030 Floorboard Vibration #34
Observe :D
   / B3030 Floorboard Vibration #35
Thanks DN - I actually found them on my own last night (now that I knew I should be looking for them).:rolleyes:
   / B3030 Floorboard Vibration #37
To answer Haz's original question, no I didn't get that from the manual :) Just out of curiosity I dug my manual out, and all it says under REMOVING THE LOADER is:
9. Remove the mounting pins from the loader main frame and hold them on boom.​
No illustration, questionable grammar. Indeed, they could've been a little more specific. I like that they're within easy reach w/o getting off the tractor.
   / B3030 Floorboard Vibration #38
ethiojazz said:
Is the 4 cyl more shaky than the three?? I just got a quote for a 3030 which was only 1000 more than the 2630. It seemed to make no sense to me until I read this thread. And if anyone had the old 2710 and 2910 could you comment if they also vibrated?? In trying out tractors I dont remember them being any more vibration thank my 2410.
I have a 2001 B2910 with about 950 hours on it, and I can confirm that there is a little vibration, but it's only noticeable if you are sitting still and concentrating on the vibration. Otherwise if you're doing something that requires your attention, It's not noticeable. Like others have said, the vibration is more pronounced at certain RPM's. I've used mine for up to 10 hours straight, and I've never had any part of my body go numb except my bum (from extended sitting, not vibration).:D
If I want to get a job done, I can always rely on my Kubota to outwork me every time. If I want to be comfortable, I'll go sit in my recliner with a beer in one hand and the remote in the other. :D
   / B3030 Floorboard Vibration #39
Thanks Bubba,,,
Spoke to a couple of dealers and they said the same.. Both with the 2710/2910 and the 7800...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
2013 John Deere 350G LC Hydraulic Excavator (A55787)
2013 John Deere...
2017 Dodge Charger Sedan (A55758)
2017 Dodge Charger...
Terms and Conditions (A47477)
Terms and...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
