B3030 cab
/ B3030 cab #1
Jethro
Eastern NC
Kubota B1550, several Exmark ZTRs, Walker GHS and a 1967 Craftsman Surburban
I have heard that the cab for a B3030 must be installed at the time of manufacturing. I would think you could order one later and install it yourself. Any one have any experience with this?
/ B3030 cab #2
This is America and anything can be done here. That said, I just went out to the barn to look mine over (B3030 w/ cab).
The cab has A/C so another radiator will need to be installed and plumbed.
The wiper and work light switches wired in. With a factory installed cab they are on the dash, so you'll either have to cut two holes for them or mount them another way.
If you have a FEL the joystick will have to be moved and replumbed. A differant style joystick is used with the cab.
ROPS bar will need to be removed for the cab. ROPS is incorperated into the cab.
These are just a few things that will have to be considered.
The big question I would have is "Can I get a cab sold seperately?"
Best of luck to you.
/ B3030 cab #3
I should also add that a BH cannot be used with the cab model. Hopefully someone is going to come out with a BH that will work with the cab but as of three months ago I hadn't found anything. Then again, it's not a high priority with me.
/ B3030 cab #4
Hi Atlas,
The new Woods BH70x, and BH80x series backhoes will work with a Kubota B3030HSTC.
/ B3030 cab #5
ChuckinNH said:
Hi Atlas,
That's good to know. Thanks!
/ B3030 cab #6
The B3030 factory cab is installed at the plant, to add it later is foolish. Curtis makes a good cab, i owned one. Lauren also makes a cab so nice, you would think it was factory!
/ B3030 cab #7
I have learned from experience that there are lots of things that Kubota offers as a factory installed item, that can not be ordered separately for installation later on. It might be the legal department sees this as a large liability issue, or it might be that it is so integrated into the machine that to add it later on would be like rebuilding the machine and would be cost prohibitive. It is alway less expensive to order it the way that you ultimately want it from he factory than it will be to try to retrofit a machine later on. In the 1960's it was commonplace to add air conditioning, power steering, power brakes, etc. to cars. Today, it can't be done because they are too complex and the parts all have to be integrated for everything to work as planned. Same for the modern day tractor. It is no longer just a cab, but part of a greater system that can't be modified after production. Dusty
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
Street Sweeper (A60352)
Street Sweeper...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
(2) DROP LEGS (A64280)
