B3030 Alternator Upgrade
   / B3030 Alternator Upgrade #1
asmithcars
Woodstock, MD
B3030, ZG327
Has anyone installed the B3030 alternator upgrade 'cause I am and have a question? I'm installing the alternator upgrade (Kubota) so I can add work lights. All went well until I went to hook up the harness under the 'dash.' The only matching connector on the original harness is a 6-pin one using all 6 pins; however, the new harness is a 6-pin housing using only 2 of the pins. Hooking these together also eliminates what looks like regulator - it has cooling fins and is also under the 'dash.' Does anyone know if this is the correct hook-up? (I don't want to fry the new alternator with an incorrect connection.) Thanks
   / B3030 Alternator Upgrade #2
The thing that looks like a regulator is a rectifier and regulator. I removed it and used the bolt to mount the regulator.
BrianW--thanks for the info, and I presume from your reply you did hook the new harness to the old harness as I mentioned (new 6-pin connector using only 2 pins to the old 6-pin connector?)
   / B3030 Alternator Upgrade #4
Yes, the six pin connector now only has two wires used. I had the same concerns as you, but my dealer verified the connection.
   / B3030 Alternator Upgrade #5
Anyone have a scanned copy of the instructions for doing the changeover?? Also..what was the approx cost of the new setup?
I have to do mine in spring of 2007....that "dynamo" is a JOKE!!
   / B3030 Alternator Upgrade #6
The B7324 alternator kit should be about $180 from your dealer. I don't have the instructions as mine was done at the dealers during a service. They did disconnect and leave the regulator under the dash. Too much hassle to get it out.
   / B3030 Alternator Upgrade #7
wow, that's cheap, the dealer wants over $500 for a new alternator for my L. that one isn't getting fixed soon.
   / B3030 Alternator Upgrade #8
I wouldn't be surprised if they were the same part numbers for the actual alternator. The B series part number is 16241-64012. The price by itself is $299.74 according to TractorSmart. I'd check with Messick's.
Thanks to all for your comments. I completed the alt upgrade once I received BrianW's comment about the connector issue I had. All's fine and working now.
Here's my comments answering some of the questions from others... 1. My dealer charged me $166 for the alt kit; 2. The instructions are rather sketchy, therefore my questions here; 3. I removed the original regulator/rectifier (?) from under the dash and used that bolt hole to attach the additional relay. (I got the dash panel moved away enough to work the wiring issues by removing one screw, a number of built-in clip-like attachments between the dash instrument panel and the larger part of the dash. Disconnecting the tach cable was also necessary to move the instrument panel.) Oh, almost forgot...removing the steering wheel makes moving the dash panel easier. The whole job took about 2.5 hours.
Once I get the work lights attached and working, I'll post pics.
   / B3030 Alternator Upgrade #10
I think the worst part is drilling out the engine casting for the larger alternator bolt. It looks like there is a bushing in there, but I could not drive it out so I drilled it out. BTW, I think the reason the six wire connector only uses two wires is because on the dynamo the connection is to a regulator/rectifier and on the alternator the regulator is in the alternator. The only connection to the tractor at that six wire plug is to the idiot light and probably a ground or switched power. Someone with a schematic could confirm.
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
100 GAL L SHAPED FUEL TANK (A50854)
100 GAL L SHAPED...
