B3030 Alternator Upgrade
   / B3030 Alternator Upgrade #11
If it is the same as the BX2230 kit, pretty sure the alternator has internal regulator. If you look at the schematic for the dynamo circuit, it puts out AC to the regulator where it has a full wave bridge split in to 2 circuits one for charging and the other for the lights(so the lights run off -12vdc). When you remove this small regulator/rectifier unit you only need the jumpers and a couple wires to the alternator and that is it.
David Kb7uns
   / B3030 Alternator Upgrade #12
BrianW said:
I think the worst part is drilling out the engine casting for the larger alternator bolt. It looks like there is a bushing in there, but I could not drive it out so I drilled it out. BTW, I think the reason the six wire connector only uses two wires is because on the dynamo the connection is to a regulator/rectifier and on the alternator the regulator is in the alternator. The only connection to the tractor at that six wire plug is to the idiot light and probably a ground or switched power. Someone with a schematic could confirm.
I would like to get the alternator upgrade. So drilling is required? That would make me a little nervous too. I havent heard of anyone else talk about drilling.
I did not have to do any drilling. The parts in the kit allowed me to utilize the original hole for the lower alternator bolt. It took me a couple of minutes to figure it out though. I used the smaller of the kit's 2 bolts, the supplied spacer to line up the v-belt, and a sleeve to go into the original hole in the block to accomodate the smaller diameter bolt. All that stuff is held in place with a washer, lock washer, and nut.
Although I forgot to mention it in my origianl posts, you need to remove the original oil dipstick housing. Just unbolt it and wiggle it, and pull it out - its held in by an O-ring. The new dip stick goes directly into the hole where the original dip stick housing went into the block. Good luck doing yours.
   / B3030 Alternator Upgrade #14
Re the dipstick: I tweaked the bends in the original dipstick tube so that it clears the alternator, that way I can use the longer original dipstick and not have to remove the side panel to check the oil level. :cool: I learned that from a previous post here on TBN.
   / B3030 Alternator Upgrade #15
You folks will be able to run anything with the alternator, im running worklights,heater,stereo and wipers with power to spare!
   / B3030 Alternator Upgrade #16
Id just like to be able to run 2 work lights and one cigar lighter....*S*
   / B3030 Alternator Upgrade #17
My B7500 ate a battery every winter without fail, now i know why.
Thanks. I do look forward to seeing in the dark, and I hadn't thought of installing a stero, but now I think I will. (That outta thrill the neighbors as I listen to the Stones, AC/DC, Lead Zepplin, and REO Speedwagon.)
   / B3030 Alternator Upgrade #19
Hey thats funny you should say that smitty, we must be close in age. One of my favorite tunes to play on my cd while performing large aerations,etc, is no quarter from the song remains the same, also love the stones,yes,beatles,grateful dead and skynyrd. We have xm in our house,tahoe and the dumptruck, havent got it in the kubota yet!
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
19010 (A48082)
19010 (A48082)
2008 SHOP BUILT  STEEL TANKER TRAILER (A50854)
2008 SHOP BUILT...
