B2920 work lights
/ B2920 work lights #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
Let me add yet another work light thread... See attached pics.
I got two 1000 lumen LED lights, Soundoff Signal brand. Very nice lights, cost about $100 each with shipping. Each draws 1.4 amps at 12V.
Mounted one facing forward, attached to the threaded boss on the right ROPS upright, near the hinge. This boss happens to have an M10 1.25 pitch metric thread, which I discovered after some trial end error and a couple trips to the hardware store buying bolts (tried 3/8-16, 3/8-24, then M10-1.5, M10-1.0, and finally M10-1.25). I bolted the light bracket to the boss with a large fender washer behind it to add some stability. It's very solid.
The other light is facing aft, and mounts in a hole on the right fender which is probably intended for a work light. I used fender washers here for support, and it occured to me that it's the first time I have used a fender washer on an actual fender!
Power came from the prewired worklight leads taped in the right fender. I ran 16GA wiring inside 1/4" split loom tubing, and routed to the blank panel on that fender. I installed two rockers there, one for front and one for rear. I originally got two water resistant switches from West Marine, but wasn't thrilled about the cost -- $40 for the two switches. While buying some other parts at my local Ace hardware, I spotted some rocker switches that looked nearly identical, and were labeled for marine panel use. At $6 each, I figured it can't hurt to give them a try, so I'll return the pricey ones on Monday.
I added hookups for another forward facing light on the left upright, but don't think I'll need it just yet.
/ B2920 work lights #2
Nice looking job.I just upgraded my auxiliary lights last week from halogens to LED.It was a definite improvement.
/ B2920 work lights #3
Nice switch install. I bet those lights are bright. great job
/ B2920 work lights #4
>>>>219<<<<
Really great looking setup,its sad you couldn't have taken the time to clean the tractor off before taking the pic.
Army Grunt
/ B2920 work lights #5
Very nice job! Your switch install is identical to the route I chose :thumbsup:
B3200HSD Worklight Install
/ B2920 work lights #6
I have a B2320 and was going to mount my lights in the identical manner as you.... Im 6'4'' and was worried about mounting the lights on the rops that near my line of vision. Please give us some feedback as to how you like your rops lights. It is really the only logical place to put them unless you go with a rops bracket mount.
and yes I think it will also be the first time for me using a fender washer on fender... :laughing:
thanks in advance
/ B2920 work lights
It is a logical place to mount and none of the other alternatives really appealed to me. You could even tweak the bolt length to still snug up the ROPS, which is the main purpose for those bosses. I am real happy with that mounting, and I think sandwiching the fender washer behind the light bracket really helps stabilize what would otherwise be a small base.
I used the lights tonight, and the rear-facing light is perfect as-is. The front-facing light needs to be aimed down a little bit to illuminate more of the ground (initially, I installed the lights aiming straight/level). I do detect some light making the outer rim of my eyeglasses glow, but it's not enough to be a bother. I am only 6'1" though, so you may want to do a mockup and run the lights before you decide to commit to that mounting.
/ B2920 work lights #10
Was this on the stock alternator, or do you have an upgrade? I have the stock one, interested in knowing if this will work.
/ B2920 work lights
LEDs are fine on the stock alternator -- each light only draws 1.4A (and less bright lamps go even lower).
/ B2920 work lights #12
I would assume that you used a flood for the rear but did you also use a flood patten for the rops lights>?
/ B2920 work lights
/ B2920 work lights #15
Does anyone have pictures of the Kubota rear work light kit, installed? I have a L3800 and my dealer wishes to install something other than what it said it would include upon purchase. I like the looks of the replacement but wish to see what Kubota lights look like? Can't find pics of Kubota model L8327 rear kit.
/ B2920 work lights #16
Perhaps this will help:
* Parts diagram
* Actual pictures
/ B2920 work lights #17
attachment.php
attachment.php
