B2920 Wheel Slip
/ B2920 Wheel Slip #1
Hunter29
Michigan
Kubota B2920
So The wheel is slipping in the tire, no air or rim guard is leaking.. how do I fix this?
/ B2920 Wheel Slip #2
Whats the pressure at? Otherwise it sounds like the guy who used something they shouldn't have (unapproved bead lubricant) to mount the tire should be fixing it.
Dale
/ B2920 Wheel Slip
I was just thinking pressure too, I'll have to check it. There OEM tires, mounted by kubota I would think... I bet it's the pressure, never added air in the six years I have had it.
/ B2920 Wheel Slip #4
There was a thread started about 2 years ago with the same problem. I think it was on a BX series. The problem was low tire pressure. He aired them up and problem was solved.
/ B2920 Wheel Slip #5
Look on the tire for maximum pressure and air it up to that pressure, run it a few days to well seat the tire bead then you can adjust it back down for maximum tire contact to the ground. Max tire pressure might be 25 PSI or higher while best traction might be 12 PSI or thereabouts. Usually the tires are mounted and aired up to max pressure to seat the bead, but if it has been 6 years without checking tire pressures, I am very surprised that you haven't rolled it off the rim already.
/ B2920 Wheel Slip #6
Please tell us that you at least checked the pressure...please. :laughing:
/ B2920 Wheel Slip #7
I find that hard to believe -- I have to add air 3-4 times a year (which is about how many times I check).
/ B2920 Wheel Slip #8
I have had mine for over four years and did nothing but let air out....for better winter traction, smoother ride. Funny when you think about it. Maybe the DOT will force tractor manufacturers to have TPMS too if I roll mine over when a tire comes off the rim.
Dale
Mower King SSRC (A64127)
Mower King SSRC...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
Purdy PT 60' Land Leveler (A64126)
Purdy PT 60' Land...
1967 Hyster Equipment Trailer (A66285)
1967 Hyster...
2017 PETERBILT 579 (A65643)
2017 PETERBILT 579...
