B2920 Wheel Slip
/ B2920 Wheel Slip #1
Hunter29
Michigan
Kubota B2920
So The wheel is slipping in the tire, no air or rim guard is leaking.. how do I fix this?
/ B2920 Wheel Slip #2
Whats the pressure at? Otherwise it sounds like the guy who used something they shouldn't have (unapproved bead lubricant) to mount the tire should be fixing it.
Dale
/ B2920 Wheel Slip
I was just thinking pressure too, I'll have to check it. There OEM tires, mounted by kubota I would think... I bet it's the pressure, never added air in the six years I have had it.
/ B2920 Wheel Slip #4
There was a thread started about 2 years ago with the same problem. I think it was on a BX series. The problem was low tire pressure. He aired them up and problem was solved.
/ B2920 Wheel Slip #5
Look on the tire for maximum pressure and air it up to that pressure, run it a few days to well seat the tire bead then you can adjust it back down for maximum tire contact to the ground. Max tire pressure might be 25 PSI or higher while best traction might be 12 PSI or thereabouts. Usually the tires are mounted and aired up to max pressure to seat the bead, but if it has been 6 years without checking tire pressures, I am very surprised that you haven't rolled it off the rim already.
/ B2920 Wheel Slip #6
Please tell us that you at least checked the pressure...please. :laughing:
/ B2920 Wheel Slip #7
I find that hard to believe -- I have to add air 3-4 times a year (which is about how many times I check).
/ B2920 Wheel Slip #8
I have had mine for over four years and did nothing but let air out....for better winter traction, smoother ride. Funny when you think about it. Maybe the DOT will force tractor manufacturers to have TPMS too if I roll mine over when a tire comes off the rim.
Dale
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61569)
2018 Freightliner...
2017 Chevrolet Express 12FT Box Van w/ Liftgate (A61568)
2017 Chevrolet...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
