Tires b2920 tire pressure?(turfs)
   / b2920 tire pressure?(turfs) #1
taos
canada
kubota b2920
I was wondering what the tire pressure was for the front and rear of a b2920 (turf tires ) if different.(i'm waiting for manual for tractor) dealer lost it. thanks
   / b2920 tire pressure?(turfs) #2
The maximum air pressure will be moulded onto the sidewall of the tires. If you have a FEL then I would run the fronts at the maximum allowed. That will make it easier to steer with a full bucket. If no FEL then fill them so the outside edges of the face of the tire are not quite in contact with a hard flat surface like your shop floor or driveway. The rear turf tires should be inflated so the outside edges of the face of the tire are not quite in contact with that hard flat surface with your most used attachement on the 3PH.
This will give you the best traction with the least surface damage to soft ground, sod or whatever else you are driving across. There may be times when you will want to adjust air pressure to suit attachements and surface conditions but the above is what works best for me. The manual may give you a ballpark pressure to go with but they can't know what attachments you have.
thanks guys checked pressure in tires today front were at 30psi and rear were at 28psi , and lowered them,should be getting manual soon in next couple of days
   / b2920 tire pressure?(turfs) #5
Are you sure orange? I could swear mine need 20+ for the rears.
   / b2920 tire pressure?(turfs) #6
Are you running 75D or 33's ? Anything in the mid teens will do for
turfs on these . BX turf rears runs at 10psi for a good footprint :thumbsup:
  • IMG.pdf
   / b2920 tire pressure?(turfs) #7
Getting beyond the one size fits all!! Adjust the tires for you, first thing you should have a full tire of contact on the ground. Drive it on a dusty driveway and see how much of the tire has dust on it. The sidewalls can have some flex for ride comfort or for the fronts they may be more solid for loader work.
The tire should be making a full imprint on the ground, they should not be rounded up in the center!
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2021 JOHN DEERE 6130R LOT NUMBER 46 (A53084)
2021 JOHN DEERE...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
