B2920 suitcase weights
   / B2920 suitcase weights #11
I could hang the weights on the front. I ran into problems when trying to secure them to the frame using the bolts that came with the weights.
I think if you tried to put the suitcase weights on the B2920 you would understand the problems that I ran into. If you don't have a MMM at least you wouldn't run into that problem.
The suitcase weight bolts fit through the additional bracket just fine but not the frame.
Granted, I did consider drilling out the holes so the bolts would fit or using smaller bolts that fit through the holes. I didn't want to drill into the frame. I didn't want to change the bolts that secure the weights as the bolts that Kubota supplies are good for securing the weights.
Basically, Kubota does make an additional bracket designed to accept suitcase weight so I just bought it for simplicity.
This post rates some OP pictures
   / B2920 suitcase weights #12
On mine, there is room to hang three 55-pound weights on the front frame rail. An optional bracket is needed if I wanted to hang five weights. I have never needed to bolt the weights to the frame - I do however bolt all three weights together with a long hex bolt which essentially creates one 165-pound suitcase sandwich weight.
UNUSED FUTURE MINI EXCAVATOR (3) PC AUGER SET (A57193)
UNUSED FUTURE MINI...
Adams 5T Pull-Type Fertilizer Spreader (A57024)
Adams 5T Pull-Type...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
2018 Caterpillar 12M3 (A53317)
2018 Caterpillar...
2013 Jeep Grand Cherokee Laredo SUV (A55853)
2013 Jeep Grand...
UNUSED FUTURE BS72 72" HYD BOXBROOM SWEEPER (A57193)
UNUSED FUTURE BS72...
