B2920 loader interferance with subframe?
/ B2920 loader interferance with subframe? #1
ericher69
Ontario Canada
2008 Kubota b2920
Does anyone know if I can mount the la364fl while not having to totally remove my front mount quick hitch for blower/blade?
Did a quick search but no immediate threads covering my query!
Thanks
/ B2920 loader interferance with subframe? #3
The manual advises against doing this. When you connect the loader hoses to the FEL, the quick hitch is going to leak down and potentially jam into something. The quick hitch goes off and on quite easily so I think it's worth the extra time to remove it for FEL use. I have a little moving dolly for my quick hitch to facilitate swaps.
I should have specified...
I will remove the quick hitch (mid PTO ) part to increase ground clearance.
I was more specifically looking for interference with any bolted on parts that cannot be easily removed.
Thanks
Eric
2003 Freightliner MC 331 2,800 Gallon Fuel Truck (A64194)
2003 Freightliner...
72'' snowblower make?
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Landhonor Quick Attach Adjustable Hydraulic Pallet Forks (A66408)
Landhonor Quick...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
