B2920 bogs and stalls
   / B2920 bogs and stalls #11
As other mention fuel filter also how old the diesel in the tank,plus check tank for slime etc.
Im in Great Falls Va so I dont think its due to low temps. Fuel filter sounds god . I will change asap and keep this posted in case it helps someone else.
  • Good Post
Reactions: JWR
it had to be the fuel filter - it was pretty dirty so i need to check between intervals. thank you for the feedback !
   / B2920 bogs and stalls #14
If there is enough water in the fuel lines to freeze into slugs of ice you've got one heck of a higher priority (100% of the attempted operating time) than worrying about temperature. Injection pumps and related tiny orifices' do not like water and that much water brings the whole process to a screeching halt.
New tractor. NEVER experienced it before, nor did the thought ever occur to me. But, there it was. Small diameter nipple and hose out the bottom of the tank: mass required to block is small- amount of water maybe half a thimble, if even that?
About 720 hrs and not a single engine issue. System worked as it should (water detection and collection in the filter, pre-sensitive components): and the dealer either knowingly or not resolved the water incursion issue.
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
UNUSED FUTURE 3' X 10" GALVALUME METAL SHEETS (A57193)
UNUSED FUTURE 3' X...
2012 Ford Escape XLT SUV (A55853)
2012 Ford Escape...
2020 Deere 50G (A53317)
2020 Deere 50G...
1998 INTERNATIONAL 4700 4X2 CRANE TRUCK (A57192)
1998 INTERNATIONAL...
7' ROTARY MOWER, 3PT W/ FULL SHAFT (A57192)
7' ROTARY MOWER...
