B2920 4x4 Question
   / B2920 4x4 Question #1
iplumb
Mason MI.
B2920
When I have my B2920 in four wheel drive should both front wheels spin when loading the bucket? Only one will spin at a time. Just making sure this is normal? I was thinking they would both be locked in? I guess that would make it hard to turn though.
   / B2920 4x4 Question #2
Kubota's "4 wd" has open differentials on both ends. The differential lock works on the rear tires only.
   / B2920 4x4 Question #3
Like iplumb says, open differential. It is like most 4WD systems. You can get "lockers" for trucks and my ATV/RUV have a selector to lock the front wheels, it does make them hard to steer, tears the ground up and put a lot of strain on the gears. You would really have to beef up the front differential on a tractor to stand the strain put on it by turning with a full bucket. I am sure it would also add quite a bit to the price.
   / B2920 4x4 Question #4
One of the selling points of the M7040 is that it has a locking front differential. It is unusual to have one and was a reason a tractor that size was chosen.
It has been engaged and it is quite nice to be able to yank the tractor out of axle-deep mud. The huge front tires are a factor as well.
However, it is "limited slip" or "posi-traction" in car lingo so one wheel has to spin before the other decides to chip in to help out.
Thanks guys. I just wanted to make sure something wasn't wrong. This all makes since. When my Yamaha Rhino front diff. is locked you can hardly turn.
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2022 Club Car...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2022 Chevrolet Tahoe FL SUV (A48082)
2022 Chevrolet...
