B2910 Tractor weight
/ B2910 Tractor weight #1
Leef
Iowa
Kubota B2910
FYI, when I recently rented a b2910, I was able to drive it onto the big freight scale for direct weight measurement as follows:
b2910 + la402 FEL + landpride 5ft brush cutter(med duty?) = 3260 lbs
I thought that was worth posting for others who'v guessed at weights before.
Leef
/ B2910 Tractor weight #2
Leef, this is good info. Please tell us what model Landpride brush cutter you have. We can then subtract it. I have a Landpride catalog and they also have a website. What type of tires do you have and are they filled?
Glenmac,
This was a rental tractor I used to try out the r-4 tires (see "Tire question with a new slant" thread. The tires were not filled.
My own b2910 now has fluid filled turf tires to help with stability. I should post that follow up on the other thread.
Leef
Chair (A64557)
Chair (A64557)
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2013 CATERPILLAR 299D SKID STEER (A65053)
2013 CATERPILLAR...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
