B2910 front wheel snapped off!
   / B2910 front wheel snapped off!
Dave, I wish I had seen this earlier. I could have saved you some trouble. There is a snap ring between the gear and the case that requires a special tool to get to (AND the knowledge that it is there in the first place) I am glad you did not push hard on the parts as the danger is you go and crack the case and the bill gets substantially higher! I learned this when I had to replace a bearing in my L3710.
The dealer is correct that it does not take special tools to put it back together as the snap ring "snaps" into place upon PROPER assembly.
I know the guys you used for the work. Believe me they are better than the shop we both USE to get parts from.
I just saw the part on the bolts vs studs.......... MAN! do they ever make it easy???!!!!!!!
Do you know the thread pitch etc? I gotta think Rand's has something that will work for the time being. I actually found a left hand threaded bolt there the other day. So they do have oddball stuff. Bet it is metric though and it does need to have the properly rounded shoulder.
BTW, don't toss that hub and stud set....... the studs Can be pressed out and having spares around in a pinch can save the day!
The new studs are not pressed in, But, you are right, I could use them on the other side if necessary. I was looking at the wheel and the holes are not beveled. As a matter of fact, they are held on with a nut and lock washer. I probably could have gone with a hardened metric bolt and lock washer. Well I already ordered the studs, hopefully they will send them out on Monday as promised.
I actually had pretty good luck with the former shop you mentioned. It sure was handy when you needed something. I really miss it being there.
   / B2910 front wheel snapped off! #72
I dunno, that maybe we push these things pretty hard some times. No matter the brand. Sometimes "just push harder" should equal "get a larger machine for the job". Like many tools, just because it can, does not mean it should. That could be, the tool is not correct for the job, or the job should be done differently with the tools at hand.
I have not damaged either of my tractors(previous Kubota B8200, current NH TC40D). I have bent rear implements though...
If they upgrade, they know the original will fail, they should stand behind it. Just my belief. If they sold what they thought was a reasonable product that would withstand anything less than abuse, they would not upgrade!
   / B2910 front wheel snapped off! #73
I agree, it was handy having it there and I liked several of the folks who worked there. The ONLY issue I had with the place was the service shop was, IMHO unreliable. That and they were very proud of the parts they sold..... but that is the case no matter where you get tractor stuff.
   / B2910 front wheel snapped off! #74
Hmmm, By that logic, Ford should go out and replace every car they ever sold with carburetor. Changing to fuel injection was a blatant admission that the carburetors were no good! Hopefully products evolve and technology improves. Could be the new part costs less to make.
It's not practical to think manufacturers should "stand behind" every possible defect forever. That's why warrantes have limits. You can buy extended warranties if you want to spend the money. Keep in mind, warranty costs get rolled back into next year's tractor prices. The cost of the "goodwill" stuff that gets covered for your neighbor, will be added to your next tractor. How much do you want to pay?
   / B2910 front wheel snapped off! #75
All I can say is; "for somebody who didn't even know what RTV was, you got it done, and a job well done considering the circumstances".
Back up and running better than new in 2 weeks after tearing a front wheel off?
My hats off to ya!
Lurking and feeling your pain.
I like my local dealer, but I recommend that you check Messicks for parts inventory and availability in the future.
Messick's | Dealer for New Holland, Case IH, Kubota, Cub Cadet and More | Online Parts, Sales & Service.
I went there first. I got the front axle diagram off their site and got an idea of what I would have to do and need to order. I emailed them to make sure I wasn't missing something and to make sure it was something I could do myself. They never responded. So, I called the nearest shop here in NH. Years ago there was a great shop in NC, I can't remember the name, Carver maybe, They were great on shipping everything from parts to complete tractors. To bad they are no longer in business.
My hats off to ya!
Thanks for that. When it actually comes out of the garage under its own power I'll celebrate :) . I try to look at these situations as puzzles to be solved and with all of the help people here on TBN are willing to give it is doable.
   / B2910 front wheel snapped off! #79
Great attitude :D
Thing is, stuff breaks. Sometimes the best barometer in determining a manmade device's value is in it's support structure. Messicks as well as Carvers (I remember them & had done business with them also) with their online presence are ahead of the curve and should be consdiered a value added aspect to Kubota, shame a missed communication cost them business in this case, but that is something they need to address....
Your local dealer benefited but I am somewhat surprised the situation w/the studs weren't caught/addressed before they pressed the axle in..... Glad you've found a workaround.
Looking forward to a happy ending :D
Dave
Great attitude :D
Dave
I worked with a contractor one time and we would come up on issues that I thought were impossible to surmount. I would say something like, "there's no way we can do that" and he would just shrug and say, "well, we have too" and after it was figured out and completed, he would say "that was easy." I got him a That Was Easy Button from staples :)
Yeah, I wish my dealer had spotted that as well, he could have ordered the studs with the axle.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
1275 (A50490)
1275 (A50490)
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
