B2910 Battery Light
/ B2910 Battery Light #1
dullpain
Platinum Member
Middle Tennessee
Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
Been a long time since I last posted , so if this belongs in another forum just let me know.
Battery was shot so I replaced it. Immediately got a battery warning lite on the dash with new battery. Checked with Digital Volt meter and am getting 14 V. at the battery so the alternator is putting out. Warning lite brightness decreases as RPM's increase. Lite will go out at about 2,200 RPM's . No problems with the battery charging , battery has been in 6 months now.
???? Any body got any ideas. Merry Christmas to all TBN'ers !
/ B2910 Battery Light #2
I am no expert but it sounds like a short. I would trace the wiring and make sure everything is tight and right.
/ B2910 Battery Light #3
I checked my B2910 WSM, and it gives three possibilities. 1. Wiring Harness improperly connected. 2. Alternator/dynamo bad. 3. Voltage regulator bad.
If all you did was replace the battery, I wouldn't suspect any wiring harness troubles...you shouldn't have disturbed anything but the battery cables.
If your tractor is equipped with an Alternator, the voltage regulator is contained inside the alternator...PN 66436-64600
If your 2910 has a Dynamo, which most do, the dynamo may not be putting out sufficient Current to shut off the light, until you reach higher RPM's. I didn't find any reference to a voltage regulator on a Dynamo equipped tractor, but there is a "regulator" located under the main panel...under the fuel gauge area. The manual/parts list doesn't say what this regulator does.
If you have had this condition for 6 months, and no problems keeping the battery charged up, the mystery deepens. You might pull the dynamo (or alternator), and take it to a dealer, and see if they can check it out.
/ B2910 Battery Light #4
If the battery stays charged for six months then the system is good for your purpose. Use a clamp on amp meter, DC of course, and see if it will put out rated current. If not you may have some open diodes in the alternator. It may work fine for many years as is.
/ B2910 Battery Light #5
Check your fan belt, it's probably loose and needs to be tightened.
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
Ford 7000 (A64127)
Ford 7000 (A64127)
Frontier BB5060 (A64126)
Frontier BB5060...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
