B2650 Remote hydraulic valve kit
   / B2650 Remote hydraulic valve kit #1
Like Tractors
Eastern Iowa
Multiple Kubotas
I am planning on buying a Kubota B2650 ROPS, for the life of me I can't find any pictures of how the hydraulic valve, levers and couplers are mounted. I can find pictures of just about every other thing imaginable on the internet, some a little racy I might add! Is there anyone on this site that can provide pictures of how the Kubota kit is mounted?
   / B2650 Remote hydraulic valve kit #2
is that the front valve or the back one if it the back on I can post a pic for you
I failed to mention, rear remote hydraulic valves, couplers and levers. I am looking for how the Kubota Valve kit looks, not an aftermarket kit. Thanks in advance.
   / B2650 Remote hydraulic valve kit #4
here some pic this is from my b2650 .This was installed but the dealer hope it helps you . The two small black leavers in the cab connect to the valve below. You see the 4 hose come up to the back conection .
The model I am going to buy will be cabless, that seems to be the problem in finding pictures.
   / B2650 Remote hydraulic valve kit #6
The picture above is on the cab tractor and is a nice setup.
Unfortunetly kubotas silution for rear remotes on the b2650 rops is mounting a spool valve up on the rops with the hoses going up to it. It has small levers mounted on the valve. Looks absolutely terrible and I would think would be easily damaged. Not to mention they want 1000$ for it.
When I was ordering my 2650 the dealer had a customers 3350 in there for work. It had the rear remotes I thought it was aftermarket 途igged setup. Then the salesman said no that痴 the kubota valve you will be getting. I told
Him to take it off my order.
I have since installed my on 3 spool valve on the back of the 2650.
I am trying to find you a picture of the kubota Rops valve.
   / B2650 Remote hydraulic valve kit #7
This is what it will look like
And it痴 actually over 1200 with tax
378721 (A54865)
378721 (A54865)
(2) POLY ROLLING CARTS & CONTENTS (A58374)
(2) POLY ROLLING...
2017 John Deere 5090GN (A53317)
2017 John Deere...
PALLET OF CHAINS AND BINDERS (A58214)
PALLET OF CHAINS...
LOT OF FIRE EXTINGUISHERS (A58374)
LOT OF FIRE...
BUSH HOG 8 SHREDDER (A58216)
BUSH HOG 8...
