B2650 help on wheel spacers
   / B2650 help on wheel spacers #31
Glad you got it. I wanted to avoid the emissions crap on the b3350. But I only have 12 hours on mine and I am finding myself looking for more H.P
Ya I did the same, overall works very well for my 5 acres but after I blew up the 47" blower on the little JD 425 could use more hp for the snow removal for sure. I think I would want a big jump up if went bigger though.
   / B2650 help on wheel spacers #33
Part of me wishes I would have got the l2501. I would like the extra weight and heavier duty chassis and loader. Even tho I wouldn’t have a difference in HP. But I just didn’t like the stripped down tractor. If they had an L series that was between the 01 and the grand L I think that would be perfect.
I will have me a grand L cab tractor one day when I acquire land.
Baby steps=]
I didn't really look past B series and 2650 with the back hoe handles very good for me. A little unsure how it will handle when I get some 3pt attachments? I am thinking the grand L would be the one as well.
   / B2650 help on wheel spacers #35
The B2650 handles a 60" box blade and 72" rear blade very well. IMG_20180318_160150183.jpgIMG_20180316_122711564_HDR.jpg
   / B2650 help on wheel spacers #36
Hey Dan. Just really curious what you are doing with your new tractor that find yourself looking for more horsepower. I would really be interested.
   / B2650 help on wheel spacers #37
Need more hp for the rear snow blower. But other than that it’s fine. I will just have to take smaller bites and go slow.
   / B2650 help on wheel spacers #38
Manageded to get the other side off today. Air impact didn't help at all, took a 1/2" breaker bar with a 6' cheater pipe to get old lugs off. New spacers went on easy and wasn't bad getting the filled tires on and off. Pretty surprised how much of a difference a 1 1/2" makes. Way better traction in snow now but noticing how some extra hp would help. Lol. Thanks for the help all.
I went through a borrowed air wrench and 2 of my own before I realized the relative needs in torque to do any good. The first ones I tried were 250 ft/lb models or similar. They are useful only if you never needed them in the first place (!) Handy for speed but no good for very tight nuts. I bought a 500ft/lb air wrench which makes all the difference. Even a 700ft/lb unit would be sensible provided you are careful with adjustment. I'm betting the one that did you no good was a 200 or 300ft/lb tool. The half inch breaker bar and 6' cheater pipe tells me you were in the 500 ft/lb range. Much more than that will twist off bolts in a lot of cases. Talking half inch or 5/8 approx size bolts.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
207282 (A52708)
207282 (A52708)
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
