B2650 fuse types?
/ B2650 fuse types? #1
Rob 80
WVA
B2650
So I blew a fuse hooking up some external lights and bought a box of new fuses but they are larger.
I'm guessing the B2650 uses mini blade.
/ B2650 fuse types? #2
Yes they are the mini blade style.
/ B2650 fuse types? #3
Technically, they are called ATM mini fuses.
IIRC, I believe ATM is still registered under Cooper/Eaton Bussmann.
My BX uses regular ATC fuses, but I always keep spares in my little box on my tractor.
/ B2650 fuse types? #4
Yes, Atm/apm, then there's the low pro style aps/att.
We always just refer to them as min, maxi or standard though, unless it's a special like the low pro minis.
I always kinda felt like the atm/att was more of a manufacturer's name, like vaseline or bandaid
/ B2650 fuse types? #5
I mounted a 6 place fuse block and covered it with a plastic container (kitchen storage type).....direct wire from the battery......completely separate from the wiring harness/set-up on my B2650....
This pic isn't the finished product, but gives ya an idea....
208315 (A58376)
208315 (A58376)
Kuhn GMD 4051 TL Trail Mower (A64047)
Kuhn GMD 4051 TL...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2024 BOBCAT T66 R SERIES SKID STEER (A62129)
2024 BOBCAT T66 R...
2013 HPX Gator 4x4 Gas Utility Cart (A61567)
2013 HPX Gator 4x4...
4ft Mini Skid Quick Attach Rotary Cutter (A63118)
4ft Mini Skid...
