B2650 Air filter maintenance.
   / B2650 Air filter maintenance. #1
Rob 80
WVA
B2650
I've got 120 hrs on mine and the filter is dusty do you guys wash your filter or simply blow them with compressed air?
I have been using compressed air to clean off the radiator from the inside where the fan is.
   / B2650 Air filter maintenance. #2
Personally, I just replace mine. Figuring a new engine costs $$.
Just cheap maintenance.
   / B2650 Air filter maintenance. #3
most are cleaned with air gently, most are dry filters which are not washable.
High pressure air can perforate a filter, do you have an inner and outer filter?
If so gently blow the outer and replace the inner as needed.
   / B2650 Air filter maintenance. #4
I wash the inner (wire screen) as prescribed by my Kubota service tech. I blow the outer out and replace that once per year after I am done snowblowing and before the loader goes back on.
Yeah i have a inner wire screen that the filter goes on it's mostly dust from mowing.
2021 New Holland C327 Compact Track Loader (A53472)
2021 New Holland...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
2008 New Holland B110 MFWD Loader Backhoe (A53472)
2008 New Holland...
