B2650 Air filter maintenance.
   / B2650 Air filter maintenance. #1
Rob 80
WVA
B2650
I've got 120 hrs on mine and the filter is dusty do you guys wash your filter or simply blow them with compressed air?
I have been using compressed air to clean off the radiator from the inside where the fan is.
   / B2650 Air filter maintenance. #2
Personally, I just replace mine. Figuring a new engine costs $$.
Just cheap maintenance.
   / B2650 Air filter maintenance. #3
most are cleaned with air gently, most are dry filters which are not washable.
High pressure air can perforate a filter, do you have an inner and outer filter?
If so gently blow the outer and replace the inner as needed.
   / B2650 Air filter maintenance. #4
I wash the inner (wire screen) as prescribed by my Kubota service tech. I blow the outer out and replace that once per year after I am done snowblowing and before the loader goes back on.
Yeah i have a inner wire screen that the filter goes on it's mostly dust from mowing.
2017 Ford F-750 Crew Cab Terex Hi-Ranger 6TC-65 65ft Insulated Bucket Truck (A56858)
2017 Ford F-750...
Club car (A56859)
Club car (A56859)
2009 CATERPILLAR 308D CR EXCAVATOR (A52709)
2009 CATERPILLAR...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
Case SR210 Rubber Tire Skid Steer, Diesel Engine, Auxiliary Front Hydraulics, Hard Rubber Tires, (A59076)
Case SR210 Rubber...
