B2650 Air filter maintenance.
   / B2650 Air filter maintenance. #1
Rob 80
WVA
B2650
I've got 120 hrs on mine and the filter is dusty do you guys wash your filter or simply blow them with compressed air?
I have been using compressed air to clean off the radiator from the inside where the fan is.
   / B2650 Air filter maintenance. #2
Personally, I just replace mine. Figuring a new engine costs $$.
Just cheap maintenance.
   / B2650 Air filter maintenance. #3
most are cleaned with air gently, most are dry filters which are not washable.
High pressure air can perforate a filter, do you have an inner and outer filter?
If so gently blow the outer and replace the inner as needed.
   / B2650 Air filter maintenance. #4
I wash the inner (wire screen) as prescribed by my Kubota service tech. I blow the outer out and replace that once per year after I am done snowblowing and before the loader goes back on.
Yeah i have a inner wire screen that the filter goes on it's mostly dust from mowing.
JOHN DEERE Z530M LOT NUMBER 173 (A53084)
JOHN DEERE Z530M...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2024 KMC 7406 (A53084)
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
