B2650 Air filter maintenance.
   / B2650 Air filter maintenance. #1
Rob 80
WVA
B2650
I've got 120 hrs on mine and the filter is dusty do you guys wash your filter or simply blow them with compressed air?
I have been using compressed air to clean off the radiator from the inside where the fan is.
   / B2650 Air filter maintenance. #2
Personally, I just replace mine. Figuring a new engine costs $$.
Just cheap maintenance.
   / B2650 Air filter maintenance. #3
most are cleaned with air gently, most are dry filters which are not washable.
High pressure air can perforate a filter, do you have an inner and outer filter?
If so gently blow the outer and replace the inner as needed.
   / B2650 Air filter maintenance. #4
I wash the inner (wire screen) as prescribed by my Kubota service tech. I blow the outer out and replace that once per year after I am done snowblowing and before the loader goes back on.
Yeah i have a inner wire screen that the filter goes on it's mostly dust from mowing.
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
Roose Hog Cart (A50515)
Roose Hog Cart...
2020 CATERPILLAR Tl1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
FIATALLIS MOTOGRADER (A50854)
FIATALLIS...
