B2630 tractor stalling
   / B2630 tractor stalling #1
ezatu
So with all the snow here in New England I'm really depending on this tractor. Been great all winter but just ran into a problem today. Tractor starts up and idles fine however when I hit either the forward or reverse peddle it dies. I checked both air filters and they look clean. Actually removed them both and same problem exists. Fuel sould be OK since its been treated and machine is fine at idle.
I'm thinking dirty or clogged fuel filter. Just looking for comments and / or suggestions.
Ed
   / B2630 tractor stalling #2
Change the fuel filter and make sure you bleed the system to expel the air, you then should be good to go. You didn't say how many hours you had on tractor or when it was serviced last.
DevilDog
   / B2630 tractor stalling #3
Check the fuel cap......frozen and or dirty and won't let air in....just a thought. Check out air filter as well
Sent from my iPhone using TractorByNet
Thanks guys. Changed fuel filter early last year but it does look a bit dirty. Will check fuel cap as well.
How would I expel air if I do change the fuel filter?
   / B2630 tractor stalling #6
Had the same problem a few years back on a B1700....Iced up fuel filter restricting fule flow. Engine would idle but die when more RPMs called for.
Thanks all. Just watched a YouTube on expelling air. Gonna attack the filter with a hair dryer later.
   / B2630 tractor stalling #8
Do you have a manual, after fuel filter change/clean the injector pump has to be bled .
DevilDo
g
   / B2630 tractor stalling #9
What about the seat safety switch?
It would behave exactly as described.
On my B3030,I can stand next to the running tractor and push on the hydro pedal ever so lightly and it will just barely creep.Push just a little bit more and the tractor shuts down.
Perhaps check/bypass the safety switch and try again.
Good Luck!
   / B2630 tractor stalling #10
After re=reading the OP problem description ( I assumed it was when engine speeds up) I agree with NUMBER TWO...sounds like a seat switch.
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
