B2601 Auger options
/ B2601 Auger options #1
AndyW
2019 Kubota B2601 TLB
Hi All,
So really enjoying and getting good use out of our B2601. At around 15 hours currently. Looking to get an auger 3PH attachment. Pretty sure I want one of the Everything Attachments ones but which...the subcompact version or the compact version? Any other recommendations? I have a third function kit but the lower flow rate and the cost of something like an SA20 SSQA makes it less attractive. Any advice appreciated!
/ B2601 Auger options #2
I am currently considering an ssqa hydraulic post hole digger for my L4060. I looked at Everything Attachments 3 point implements, and for your machine the second model listed seems well sized (the first one being marketed for sub compacts). I have a similarly sized 3 point post hole digger that I have used successfully on a B8200, L3410, and my current L4060. I should probably just keep it, but with 2 fencing projects coming up, the hydraulic unit seems attractive.
The best advice would be to call them and get their recommendation. I have yet to do business with EA, but I have heard great reviews of their products and services.
/ B2601 Auger options #3
If you have compacted, difficult soil, the shorter boom design on our Land Shark compact/subcompact post hole digger will give you the most ability to lift the auger out of the ground. It comes standard with a 36" long auger, but we can include a 48" instead, for the same price. A B Series should have 15" of clearance with a fully raised 48" long auger.
Travis
This illustrates the difference. BX shown, but the same concept holds true for B series and other tractors in the small compact category.
You can see it in action, with a 36" auger, on our B and BX Kubota here:
Travis
Thx! So what is the Compact model for? It seems more robust and adjustable.
2005 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2005 Hypac C530AH...
PALLET OF PRESSURE WASHER FUEL TANKS (A68842)
PALLET OF PRESSURE...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
1998 GMC SIERRA 1500 (A67714)
1998 GMC SIERRA...
2003 International 7400 T/A Dump Truck (A66736)
2003 International...
