b26 specs
/ b26 specs #1
bx24d
Can anyone confirm the weight of a b26 without the hoe attached? I'm contemplating upgrade from BX24 to b26 or B3030 and like the increased lift capacities bucket specs on the b26. Not sure if the weight will be a little damaging to the areas I plan to use it.
/ b26 specs #2
The attached, if I can get it to attach will answer all your questions regarding the B26 and the weight without the BH. :)
The Gotcha Man
  • spec 1 scan0001.pdf
  • spec 2 scan0001.pdf
  • spec 3 scan0001.pdf
  • spec 4 scan0001.pdf
/ b26 specs #4
swampvol said:
Kubota specs the b26tlb to weigh 4001lbs. http://www.kubota.com/f/products/b26/pdf/b26.pdf
I would estimate 2600-3000lbs minus the bh.?.?
None of the specifications that came with my B26 lists the weight of the backhoe alone. My other attachments would give you the weight that you are looking for by just adding the appropriate weights. :)
The Gotcha Man
/ b26 specs #5
gotcha said:
The attached...will answer all your questions regarding the B26...The Gotcha Man
Thanks mate.
Killsbros 390 Gravity Wagon (A66285)
Killsbros 390...
New/Unused Wolverine 78in Quick Attach Rock Bucket (A65583)
New/Unused...
1988 Mack R688ST (A62679)
1988 Mack R688ST...
Diesel Heater (A66408)
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
