B2400 hydrostatic problems
/ B2400 hydrostatic problems #1
jcullers4
Need some help here. I have a 1500 hour B2400 HST. Here is whats going on. All the hydraulic functions work perfectly including the FEL and the 3 point. In REVERSE the power is completely normal. Put it against a tree in reverse and she'll spin all four no problem. The problem is VERY LOW POWER IN FORWARD. It will pull itself in low range but will not climb very much of an incline or obstacle. In high range it will barely try to pull itself on flat ground, goes normal on a down hill, and you can forget it on any kind of incline. Hydraulic fluid and filter have been replaced this morning but the problem persists. Any suggestions.
Edit/Delete Message
/ B2400 hydrostatic problems #2
No replies since 5/10, I feel your pain but don't give up hope. I had what I know is a more serious problem and finally got hooked up with some documentation that helped. Your problem sounds like it can be adjusted out but if you still have issues send me a private message or something and I'll see if I can shed some light on the situation
ltafta@hotmail
Kubota B2400HSDB
Kubota KX-41-2
Ditch Witch 2310\420BH
/ B2400 hydrostatic problems #4
Your best bet is to post in Kubota forums. There is relief valves for forward and reverse. If one of the valves is stuck it can't build up enough pressure to move it well. Pick up a service manual for it. It will be the best 50-60 that you can spend.
Bobcat 709 Backhoe Attachment (A64047)
Bobcat 709 Backhoe...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2021 CAM p4EC16W102 16ft. 7000lb Utility Trailer (A64047)
2021 CAM...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
