B2320 Mulch Kit
   / B2320 Mulch Kit
Will do. It will probably be spring before I look into it. I have to stop thinking about mowing now and start preparing for snow removal. Time to go buy a blade:)
   / B2320 Mulch Kit #12
BrianW is correct, at least for the BX2200 mulch kit. I bought it and it included mulching blades and a large steel plate that you bolt under your deck with about 10 5/16th bolts. That plate also blocks the discharge chute. At $250, I'd not buy it again.
For me, it did a nice job, but I needed to switch from full discharge to mulching, and it was just a PIA to change all the time. I built a metal plate to cover the opening, and just changed it out when I needed to mulch.
Worked fine; haven't had the mulch kit on since.
ron
   / B2320 Mulch Kit #13
mcrame01
I know what you mean about the snow. I don't intend to put the mowing deck back on until next May.
RonR
Did you leave the mulching blades on the deck and than "plugged" the discharge? Do you by any chance have any pictures of the plate?
   / B2320 Mulch Kit #14
Easygo,
I left the non-mulching blades on. I was mowing slowly (small area), so maybe it wouldn't be satisfactory if you had a lot to mow and wanted to go fast.
No pics of the plate (mower is stored now), but it was 1/8" plate that cover the discharge opening. Then welded two tabs on it to bolt to the deck.
ron
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
Freightliner Tender Truck - Adams Tender (A56438)
Freightliner...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
