I asked my local Kubota dealer if I could put bigger cylinders and if necessary a a pump to increase the load I can handle. He said the changing the cylinders will tear up the pump which thinking about it sounds about right because of the pumps ability or lack of to keep up with the flow required. So change the pump but he said that is the only pump Kubota makes that will fit the B2320. Well from buying the skid steer attachment converter form a La 504 loader to put on my L304, I would think it's possible�f the LA504 has more lifting capacity that the L304 it might be true that the pump and cylinders would interchange. The Machine the LA504 comes on is a B26XX something and I would look it up but in my humble opinion, Kubota's web sire sucks big time and it's sometimes impossible to find technical data like this.
Anybody else try and succeed doing this and have some part numbers they could share, especially for the pump but I'm reasonably sure I can deal with the cylinders. All info would be appreciated including the cylinders so I don't have to find them. I've measured the length from center to center of the cross tubes and found tons of cylinders that would fit but have to make sure the existing pump can handle or find the pump that will handle it and has the right mount for my tractor. What other info do I need to provide to make sure it'll work? Not sure how many different motors and possible pumps were available on the B2320.
One other thing. Is there a nomenclature plate for the transmission somewhere so I can make sure any pump recommended has the same mounting bolt pattern?
