B2320 HSD Stump Grinding
/ B2320 HSD Stump Grinding #1
luthergoomer
Kubota B2320
Considering purchasing a Worksaver SG-26 3 point stump grinder for my B2320 HSD but not sure it will handle it without issue. Has anyone tried this setup?
/ B2320 HSD Stump Grinding #2
Just look at the recommended hp for the grinder and the hp of your tractor. If they are close see if you can demo it.:2cents:
/ B2320 HSD Stump Grinding #4
I have looked around on the internet a bit and I think I have found the perfect stump grinder for you. The Woods TSG50, 15-50hp.:2cents:
/ B2320 HSD Stump Grinding #5
I don't recall who it was, but we definitely have a member here running a stump grinder on a BX series tractor. I do recall he was content with the performance. I'd guess that as long as you are taking small bites, it would be reasonable to do your own stumps.
/ B2320 HSD Stump Grinding #6
If you are doing it to make a living, it is too small. If you are doing it for your own use, then it should be fine.
That was sort of my thought just needed a second opinion. Thanks to all that replied.
/ B2320 HSD Stump Grinding #9
Worksaver is a "GOOD" company. Quick replies to questions -well built equipment.
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
2017 Mack Semi (A64047)
2017 Mack Semi...
SILVER EAGLE CST20W 5TH WHEEL DOLLY (A64277)
SILVER EAGLE...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
