B2320 HSD Stump Grinding
/ B2320 HSD Stump Grinding #1
luthergoomer
Kubota B2320
Considering purchasing a Worksaver SG-26 3 point stump grinder for my B2320 HSD but not sure it will handle it without issue. Has anyone tried this setup?
/ B2320 HSD Stump Grinding #2
Just look at the recommended hp for the grinder and the hp of your tractor. If they are close see if you can demo it.:2cents:
/ B2320 HSD Stump Grinding #4
I have looked around on the internet a bit and I think I have found the perfect stump grinder for you. The Woods TSG50, 15-50hp.:2cents:
/ B2320 HSD Stump Grinding #5
I don't recall who it was, but we definitely have a member here running a stump grinder on a BX series tractor. I do recall he was content with the performance. I'd guess that as long as you are taking small bites, it would be reasonable to do your own stumps.
/ B2320 HSD Stump Grinding #6
If you are doing it to make a living, it is too small. If you are doing it for your own use, then it should be fine.
That was sort of my thought just needed a second opinion. Thanks to all that replied.
/ B2320 HSD Stump Grinding #9
Worksaver is a "GOOD" company. Quick replies to questions -well built equipment.
