b2320 height
/ b2320 height #1
Jadd
bx 1850 kubota
Can anyone provide me with the overall height of the B2320 w/ turfs w/ rops extended and folded. Garage door height may be a issue. Specs not available on Kubota's site.
/ b2320 height #2
Jadd
With ROPS folded, the over all height is less than 6 feet. It goes into a standard garage easily. With ROPS up, it will not go into a standard 7' garage door opening. Over all height is 7' 6", approximately.
An 8' door opening is required. Hope that helps.
PS- I believe the turfs will make the tractor shorter, but not short enough.
/ b2320 height #3
On my B2620 there is a position between up, and folded that can be used, and I usually have mine there most of the time. It is high enough to protect me, and just fits under my 7' garage door. Good compromise.
/ b2320 height #4
Chuck...would you explain what was needed to be able to convert your front loader to mount forks? This is the primary reason I'm looking at Deere...with the quick attach bucket. My Kubota dealer tells me the B3300 is the one with QA in the smaller tractors.
Randy
