b2320 height
/ b2320 height #1
Jadd
bx 1850 kubota
Can anyone provide me with the overall height of the B2320 w/ turfs w/ rops extended and folded. Garage door height may be a issue. Specs not available on Kubota's site.
/ b2320 height #2
Jadd
With ROPS folded, the over all height is less than 6 feet. It goes into a standard garage easily. With ROPS up, it will not go into a standard 7' garage door opening. Over all height is 7' 6", approximately.
An 8' door opening is required. Hope that helps.
PS- I believe the turfs will make the tractor shorter, but not short enough.
/ b2320 height #3
On my B2620 there is a position between up, and folded that can be used, and I usually have mine there most of the time. It is high enough to protect me, and just fits under my 7' garage door. Good compromise.
/ b2320 height #4
Chuck...would you explain what was needed to be able to convert your front loader to mount forks? This is the primary reason I'm looking at Deere...with the quick attach bucket. My Kubota dealer tells me the B3300 is the one with QA in the smaller tractors.
Randy
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
Kivel Quick Hitch Skid Steer Attachment (A64553)
Kivel Quick Hitch...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2016 Freightliner 108SD 26Yd. Side Loader Garbage Truck (A64194)
2016 Freightliner...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
