B2320 Front Weights
   / B2320 Front Weights #1
maximus1277
Manchester CT
2010 KUBOTA B2320, 2010 KIOTI CK27, Kubota L3940,JD110 TLB
Does anyone have front suitcase weights on B2320 with FEL? I don't know if weights will fit with the FEL attached - neither does my dealer. The tractor is really light and front end pushes a bit especially with the backhoe attached (Woods b70x). Could use some traction on this machine - any advice would be appreciated.
   / B2320 Front Weights #2
Woods used to have front weights installed when a 70X was used on a B7610....... perhaps they recommend the same on the 2320? Their front weights definitely worked with the loader on.
   / B2320 Front Weights #3
If you go to the US Kubota site and build a B2320, they have a front weight bracket option for 100$ and weights ( 74 $ each ).
I don't know if they are compatible with the loader. They mention no restrictions.
Gyro
   / B2320 Front Weights #4
Gyro
I think the weights will interfere with the loader when it is the lowered position. Why not put some dirt in the bucket?
Kobalt 10 Inch Miter Saw (A57454)
Kobalt 10 Inch...
1991 Snowco Trailer (A59814)
1991 Snowco...
VERMEER PD10 PILE DRIVER (A60429)
VERMEER PD10 PILE...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59575)
1999 TRANSCRAFT...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
Zero Turn Mower (A59231)
Zero Turn Mower...
