Dirt Moving B2320 box blade size?
/ B2320 box blade size? #1
displacedPA
SC
NH T2310
What is a good size box blade for the B tractors? I know its best to try and cover your rear tire track width. I saw one user here using a Land Pride
BB0548 on a B2920. While other users have used a BX size blade... on a B. My thoughts are to add the box blade to the price of the tractor up front. I dont want to hastily pick a box blade just so that I can order my tractor. I will use it rather extensivly to grade my lot so that i can build my garage...
/ B2320 box blade size? #2
I have a 4 ft with our 2320. May be able to use a 5 ft if just smoothing out light materials. If using the rippers in anything but very sandy conditions I think you'll lose traction because of the weight of the tractor.
May want to add what tires you have and what kind of dirt you'll be working in. A lot much more knowledgeable than me will chime in if given more details.
/ B2320 box blade size? #3
I have a B2630 with a 5ft box blade. The weight of the box is right at the max for the 3pt hitch and it provides a great counter balance for the FEL when do dirt work. I like that it is wider than my tractor tires too. I have only used it to spread loose dirt and scrape high spots.
The tires will be R4s. And the grading will be quite extensive. Sounds like a four foot blade would be the right size
/ B2320 box blade size? #5
I have R4's on my B7800 and pull a 5' BB. I put my lawn in recently, about 2 acres, and used it extensively. My tires aren't loaded so traction is an issue and 4wd is a must. I found the key is to make multiple light passes and don't try to do too much at once.
/ B2320 box blade size? #6
I have a Bush Hog brand 5' blade for a B2920. It weighs 490 lb. Probably similar to the BB25 Land Pride. As I do not have loaded tires, I use it as weight when I use the FEL. By using the top link to adjust the depth it is digging, I am usually ok with it, but it will occasionally stop me due to lack of traction. Mostly I use it on our 400' drive on the gravel.
Land Pride does have a BB15 series that is a bit lighter built and available in a 54" if you wanted something wider than your tracks.
/ B2320 box blade size? #7
I would also agree on the 54" box blade-seems like a good fit for the B2320.Great counterweight for FEL work.Good Luck!
/ B2320 box blade size? #8
I use a 4' with my BX2360 and the guys I know that use a B series either have a 4' or 5' box blade MAX. These things get terribly heavy when they start filling with material.
As the previous poster said they are EXCELLENT counterweight for FEL work.
2000 Sterling Rollback L9500 Series Truck, VIN # 2FZNEWEB1YAG12895 (A65563)
2000 Sterling...
Skid Steer Hydraulic Adjusting Forks (A65640)
Skid Steer...
2022 EZ-GO ELITE...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2001 Volvo Sleeper (A62613)
2001 Volvo Sleeper...
6x12 Leonard Utility Trailer (A65579)
6x12 Leonard...
