B2320/b2620
/ B2320/b2620 #1
GSmith4965
This is a question for the diesel mechanics on the forum. The b2320 is rated at 23 hp/17hp pto while the b2620 has 26hp/19hp pto. Both tractors use the same engine. What differences would produce more hp in the b2620?? Would it be larger injectors? Different injector pump?
I know, say with diesel trucks, much can be done to dramatically increase hp and fuel economy, etc
Do tractors such as described above respond to "tuning" mods in the same way??
/ B2320/b2620 #2
I can't answer your question but according to the Kubota website the two tractor engines have different model numbers.The 2620 is a D1105 while the 2320 is a D1005,which is the same engine model number for the BX2660 and BX2670.
/ B2320/b2620
Kcender. Agree with your engine model comment but if you drill deeper the block and head part numbers are the same
/ B2320/b2620 #4
The B2620 has a larger displacement than the B2320, so it must be a longer stroke engine with a different crankshaft, connecting rods, and possibly pistons.
/ B2320/b2620 #5
I agree, bore and stroke is the easiest. Probably just the stroke in this case.
Sent from my iPhone using TractorByNet
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2025 Rippa IREAS Ripper Mini Excavator Attachment (A64553)
2025 Rippa IREAS...
Large Gun Safe (A64557)
Large Gun Safe...
