B2320/b2620
/ B2320/b2620 #1
GSmith4965
This is a question for the diesel mechanics on the forum. The b2320 is rated at 23 hp/17hp pto while the b2620 has 26hp/19hp pto. Both tractors use the same engine. What differences would produce more hp in the b2620?? Would it be larger injectors? Different injector pump?
I know, say with diesel trucks, much can be done to dramatically increase hp and fuel economy, etc
Do tractors such as described above respond to "tuning" mods in the same way??
/ B2320/b2620 #2
I can't answer your question but according to the Kubota website the two tractor engines have different model numbers.The 2620 is a D1105 while the 2320 is a D1005,which is the same engine model number for the BX2660 and BX2670.
/ B2320/b2620
Kcender. Agree with your engine model comment but if you drill deeper the block and head part numbers are the same
/ B2320/b2620 #4
The B2620 has a larger displacement than the B2320, so it must be a longer stroke engine with a different crankshaft, connecting rods, and possibly pistons.
/ B2320/b2620 #5
I agree, bore and stroke is the easiest. Probably just the stroke in this case.
Sent from my iPhone using TractorByNet
