b2150 range selector help
/ b2150 range selector help #1
bootleg
My father recently purchased a b2150 that was not maintained very well.The transmission 3 range selector lever will not budge from the medium range position.Any ideas? Is it just stuck at the pivot point?
Frustrating! !!
thanks
/ b2150 range selector help #2
It is similar to the B8200 I used to have. There should be a zerk grease fitting on it. Mine was gummed up when I got it used. Took some cleaning and penetrating fluid to free it up. And then regular grease on the zerk.
/ b2150 range selector help #3
I some times idle my tractor down, then reverse the direction of travel. You might find too that you can hit neutral, then go from there. This is based on my B3030 experience.
2017 MAC Half Round T/A End Dump Trailer (A68183)
2017 MAC Half...
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
CAT 330BL Swing Drive (A68134)
CAT 330BL Swing...
2010 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2010 CHANDLER TRI...
