B21 narrow backhoe bucket
/ B21 narrow backhoe bucket #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Looking for sources for narrow (6 inch) bucket for a B21.
/ B21 narrow backhoe bucket #2
The previous owner of my B26 bought 12" and 18" bucket but I guess he found the 18" to be too much so he cut 5" off each side to make it into an 8". This is about as narrow as you need for trenching. Anything less and you cant walk in it (or step down in it). Sorry cant help you one sourcing one other than Kubota dealer.
I do have an 18" bucket that is too much for the rocky stuff we have here. I do have a plasma cutter and a multi process welder. I also feel some inner turmoil about cutting up a perfectly good bucket.
/ B21 narrow backhoe bucket #4
I have a 10" and 16" bucket. The 10" is no fun in clay soil when it is on the wet side. Sticks inside the bucket badly.
I tend to keep the 16" on most of the time...
With a welder and plasma cutter, have you considered fabricating a smaller bucket yourself?
Bill
/ B21 narrow backhoe bucket #5
Bill
You may need to put a piece of chain in the bucket like the draglines use to help release the mud suction and break it out of the bucket on the small bucket. May even work for the 16" one too.
/ B21 narrow backhoe bucket #8
I'm unable to find any 6" buckets anywhere. I believe a 10" would be the smallest available.
/ B21 narrow backhoe bucket #9
Wouldn't a 6" jam up with rocks? Certainly on clay. I have 12" on my B21, seems as narrow as I would want. How big are your rocks on average?
/ B21 narrow backhoe bucket #10
Look at bxpanded website... You may find one!
/ B21 narrow backhoe bucket #11
Not trying to intrude on this post but does anyone have a copy of the WSM for the b21 for sale?
/ B21 narrow backhoe bucket #12
I built my own about 9" wide. That was as narrow as I could go on a BX backhoe and have the ditch wide enough for the bucket linkage and pin. I just copied the 12" bucket I had. It works good as long as it isn't muddy. You want to build in a little taper to the back and I would make it deeper if I was doing it again so it has a little more capacity.
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59914)
2006 STERLING...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2008 PRESVAC HYDRO BLASTER (A59914)
2008 PRESVAC HYDRO...
