B21 HST strainer
/ B21 HST strainer #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Seems like the HST strainer elbow tube is quite stiff. Assuming its rubber. I'm concerned about cracking it at some point. So close to the end of this task I can taste it. Only some of that is brake cleaner overspray. I'm going out with a electric heat gun now to try and soften it up. Other ideas?
/ B21 HST strainer #3
What task? Brake cleaner overspray, in relation to what/when?
/ B21 HST strainer
An attempt at a joke. Used a lot of brake cleaner where the pressure washer did not hit. Around the filter housing, and such.
/ B21 HST strainer
Can you post a pic of the strainer elbow?
It looks like a radiator hose 90 degree bend about 1 1/4 inch diameter. No matter, I did get it to come out a bit and it did not want to flex enough to pull the strainer out. The other end was up very difficult to get at and seemed to have two hose clips on it. I pulled it out as far as I could, realized it was clean as could be and called it good.
/ B21 HST strainer
Bush Hog BH317 Rotary Cutter (A64047)
Bush Hog BH317...
more info coming soon (A61569)
more info coming...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2020 Case IH 475 Speed Disk (A63109)
2020 Case IH 475...
JOHN DEERE 8295R MFWD TRACTOR (A63290)
JOHN DEERE 8295R...
PALLET OF PTO SHAFTS (A63290)
PALLET OF PTO...
