B21 block heater install
/ B21 block heater install #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Today was the day I was going to install a block heater on my B21. Thought I had a hex large enough to fit the plug that has to come out. I was wrong, or lost it.
Anyone know a cheap source of large hex wrenches, etc?
/ B21 block heater install #2
Amazon. Also use tape. I tried to used the pipe dope and couldn't get it to seal.
Sent from my iPhone using TractorByNet
/ B21 block heater install #3
Harbor Freight has large Allen wrench sockets. You will need a breaker bar and some heat to get the factory plug out. It was hard to get mine out of my B2400 block. I used a piece of hex rod and a 3 foot pipe wrench and preheated the plug with a torch.
I got the set from HF. I'm changing the thermostat while I have it drained. Anyone know the proper torque for the 12 mm bolts?
So, filled the cooling system then went to get a fan belt. Got back and there was a little pool of green liquid in the heater housing. Cleaned it up thinking I may have spilled some. In less than ten minutes the puddle was back. Keeps growing too. Wonderful.
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
(2) BUCKETS OF ASSORTED ROOFING NAILS (A64281)
(2) BUCKETS OF...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2025 Safety Basket Forklift Attachment (A61572)
2025 Safety Basket...
2017 Toyota Hybrid Pruis Hatchback (A61574)
2017 Toyota Hybrid...
