B1700 Starting Problems
/ B1700 Starting Problems #1
nick95rs
Mobile, AL
1996 Kubota B1700D
Have a 1996 B1700 with about 530 hours on it. I bought it used a couple of years ago. I have been having an intermittent starting problem with it. The engine turns over fine just does not start. I have been doing a little reading to try and figure out what is going on. When it will not start it does have smoke coming from the exhaust, so I would say that it is not a fuel problem. It did it to me yesterday. I ended up taking the air filter out and it cranked. The filter doesn't look that dirty, but I am going to order a new one. I have also checked the glow plugs. They are working. The only other thing that I know of to check is the compression. What should it be? Any other input on what to check would be great. I enjoy reading all the great post from everyone.
/ B1700 Starting Problems #2
Fresh fuel?
New fuel filter?
Junk in fuel tank/line.
Has this been happening during warm temps...gelling?
I guess I should have mentioned what I did to it last year. I replaced all of the fuel lines, drained all the fuel and put a new fuel filter on it. That was about a year ago. I replaced the fuel filter again around the first of this year. The temperature was in the 70's down here yesterday when I had problems cranking it. Once it fires off it always runs like a champ.
/ B1700 Starting Problems #4
I would test the glow plugs. This is the classic symptom for them not working. You could have intermittent issues with your glow plug relay. :thumbsup:
I did a little more checking tonight since I had a little time. I checked the voltage to make sure the glow plugs were getting power. I checked the battery and it had 12.6V. Then I put the meter on one of the glow plugs and turned the key. I had 10.4V. Not sure if I should have a full 12V there or not. Maybe someone can tell me that. Would low voltage cause them to not heat up properly? Thanks for replys so far.
I usually let the glow plugs warm between 5 and 10 seconds. Depending on temp.
/ B1700 Starting Problems #7
Did you disconnect the wire off of the glow plug before you tested? You should have between 12V-13.8V with the wire disconnected and the glow plugs on.
If you have the correct voltage you may have a bad glow plug. :thumbsup:
/ B1700 Starting Problems #8
Does the B1700 have the resistor style glow plug indicator (small hole in dash with a curly resistor wire down inside) like a B7100? If it does, you voltage reading at the glow plug sounds correct. If it does have the resistor, the glow plugs are not designed to have a full 12volts.
I also agree with Egon. Try heating the glow plugs longer.
/ B1700 Starting Problems #9
Try good 30 seconds for glow plugs.
2017 Chevrolet Express 3500 12FT Box Truck w/ Liftgate (A61573)
2017 Chevrolet...
RAYNE PLANE 41CV LAND PLANE (A63291)
RAYNE PLANE 41CV...
INTERNATIONAL CUB CADET 1450 RIDING MOWER (A63291)
INTERNATIONAL CUB...
6R BEDDER (A63291)
6R BEDDER (A63291)
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
