B1550
/ B1550 #1
sw18x
Looking
Hi all
I'm a new homeowner doing everything I can to avoid buying a throw-away Lowes lawn mower. I really like the later model Kubotas and I'm looking at a listing for a B1550 with about 2100 hours and a 5 foot belly mower for about 3K. I'm wondering what kind of life can I expect out of that 3 cylinder diesel (assuming good maintenance) and the transmission. Is there anything specific I should be looking for when I see the tractor? I don't have much experience with diesels so any information or tips you can give me on this model would be helpful, thanks.
By the way, I only have a 3/4 acre lot so not a lot to mow. It'd be nice to have a bucket to move firewood and plow with, but haven't seen anything in this price range that includes one, so it's not a necessity. As for the PTO, with the right pump I'm wondering if I could run a log splitter off the back. Again, thanks for the input.
Steve
/ B1550 #2
Hi all
I'm a new homeowner doing everything I can to avoid buying a throw-away Lowes lawn mower. I really like the later model Kubotas and I'm looking at a listing for a B1550 with about 2100 hours and a 5 foot belly mower for about 3K.".
$3K for a B1550 with a MMM, if it in good shape-buy it now!
You should expect 5000 hours on that power plant. Great opportunity for sure.
For comfort have a local shop check out the PTO via a dyno to make sure it is up to performance specs. Make sure they are diesel experts, and honest. Pay them $100 or so then buy it. Better yet, please provide me with the sellers contact info! :)
/ B1550
Thanks. I'll be having a dealer check it out first, more than likely. Does anyone know what kind of fun gadgets are easily available for the rear hitch (1) and pto? How hard / expensive would it be to mount a small loader? (there are no hydrolics currently mounted on the front)
/ B1550 #4
Is this unit 2WD or 4WD?
I think you are out of luck for a FEL on this little unit. Probably real hard to find or probably cost about as much as you pay for the used machine.
I don't think it would be worth it but others may know better?
/ B1550 #5
I have a 2 cylinder diesel with 3,600 hours, change the oil often, always use 15W40. If the front end loader is hard to find or expensive, a rear 3pt scoop would be a nice alternative, not as powerful but would work. Keep in mind, a hydraulic or PTO driven wood splitter means more hours on the tractor engine.
/ B1550
2w drive
/ B1550 #7
If its a 2wd and has directional tires, they could be reversed, giving greater traction when going backwards with the scoop. I have 2wd tractor and it mows, plows snow, and york rakes very well.
/ B1550 #8
the b1550 was a very well built tractor that would be better than a box store lawn mower know matter what shape it is in.
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2024 Freightliner M2 106 Altec DM47B-TR Insulated Digger Derrick Truck (A61573)
2024 Freightliner...
Wolverine Skid Steer Tree Digger (A64047)
Wolverine Skid...
Wolverine Hydraulic Bale Squeeze (A64047)
Wolverine...
