B1550
/ B1550 #1
sw18x
Looking
Hi all
I'm a new homeowner doing everything I can to avoid buying a throw-away Lowes lawn mower. I really like the later model Kubotas and I'm looking at a listing for a B1550 with about 2100 hours and a 5 foot belly mower for about 3K. I'm wondering what kind of life can I expect out of that 3 cylinder diesel (assuming good maintenance) and the transmission. Is there anything specific I should be looking for when I see the tractor? I don't have much experience with diesels so any information or tips you can give me on this model would be helpful, thanks.
By the way, I only have a 3/4 acre lot so not a lot to mow. It'd be nice to have a bucket to move firewood and plow with, but haven't seen anything in this price range that includes one, so it's not a necessity. As for the PTO, with the right pump I'm wondering if I could run a log splitter off the back. Again, thanks for the input.
Steve
/ B1550 #2
Hi all
I'm a new homeowner doing everything I can to avoid buying a throw-away Lowes lawn mower. I really like the later model Kubotas and I'm looking at a listing for a B1550 with about 2100 hours and a 5 foot belly mower for about 3K.".
$3K for a B1550 with a MMM, if it in good shape-buy it now!
You should expect 5000 hours on that power plant. Great opportunity for sure.
For comfort have a local shop check out the PTO via a dyno to make sure it is up to performance specs. Make sure they are diesel experts, and honest. Pay them $100 or so then buy it. Better yet, please provide me with the sellers contact info! :)
/ B1550
Thanks. I'll be having a dealer check it out first, more than likely. Does anyone know what kind of fun gadgets are easily available for the rear hitch (1) and pto? How hard / expensive would it be to mount a small loader? (there are no hydrolics currently mounted on the front)
/ B1550 #4
Is this unit 2WD or 4WD?
I think you are out of luck for a FEL on this little unit. Probably real hard to find or probably cost about as much as you pay for the used machine.
I don't think it would be worth it but others may know better?
/ B1550 #5
I have a 2 cylinder diesel with 3,600 hours, change the oil often, always use 15W40. If the front end loader is hard to find or expensive, a rear 3pt scoop would be a nice alternative, not as powerful but would work. Keep in mind, a hydraulic or PTO driven wood splitter means more hours on the tractor engine.
/ B1550
2w drive
/ B1550 #7
If its a 2wd and has directional tires, they could be reversed, giving greater traction when going backwards with the scoop. I have 2wd tractor and it mows, plows snow, and york rakes very well.
/ B1550 #8
the b1550 was a very well built tractor that would be better than a box store lawn mower know matter what shape it is in.
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59912)
2019 ISUZU NPR 4X2...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2019 TAKEUCHI TL12V2 SKID STEER (A64279)
2019 TAKEUCHI...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
Club Car (A59231)
Club Car (A59231)
