b series options
/ b series options #1
MattEffinCameron
New England
B2920
so I think I am getting a b2920...even though it is used it is coming from a dealer so I am thinking about asking them to throw some extras on it depending on price...looking for feedback on how to set it up.
1. For lighting, I know people recommend getting the upgraded alternator...but is that needed if I add LED light bars as opposed to halogen?
2. I have some interest in a quick attach...but mostly to be able to easily swap back and forth between a plow and bucket (or possibly light material bucket) for snow removal....but I am concerned about the SSQA (which I believe is the only quick attach that will allow me to pop a plow on) being so heavy that it significantly reduces the lift capability of the already somewhat limited la364. Your thoughts/experiences?
3. I will be mowing without the FEL a lot of the time so I am not planning on loading the tires, which I believe means I need some kind of counterweight for when I am using the FEL....is the Kubota Ballast Box the best option? do you just fill it with sand or whatever you have around?
4. Is a draw bar what I would need to be able to tow a trailer?
any other thoughts?
/ b series options #2
LEDs won't require the alt upgrade.
You will want counterweight for fel work. I had the rears loaded with rim guard and mowed. it's also helpful for snow clearing. Many have built there own ballast for the three point but many have also bought the factory option.
explain more about your trailering needs.
/ b series options
no real trailering needs...just have a boat, some jet skis, and a small landscaping trailer and imagine it might be useful to be able to move them around or something with the tractor at some point so I figured i would add that in there :)
/ b series options #4
My B2620 came with a draw bar but I haven't used it much. I don't know if you could put a ball on it or not.
Some people put a receiver hitch on the loader to move trailers. And you can get something to go one the three point as well.
I don't have much knowledge about going with quick attach but others will probably post up.
/ b series options #5
The 2920 comes with a drawbar. However, if you will be moving trailers frequently, I'd suggest getting a hitch receiver mount for the 3-pt hitch. You slide a standard 2" drawbar in (can be the one off your car/truck). Then you can just back up to a trailer, lift the 3-pt to hitch up, lock the hitch, and drive away. Very convenient and easy to use.
/ b series options #6
I don't think you can get the SSQA on the 20 series, you're looking at pin-on attachments for that tractor. The new 50 series has it, as well as the new 01 series that is/isn't out yet depending on where you look.
For moving trailers, definitely go with a 3pt setup - back up to trailer and lift it right up. Depending on your area and how far you are moving the trailer, you may not have to get off the tractor to latch anything. Drawbar you're at least getting off to lower the trailer onto the ball and going from there.
I have a plow for my 2650 that I fabbed up for the SSQA mount. It's super slick to swap back and forth, but I really should have found a plow with a trip edge :( I have to take it real slow as every time it catches, there's no give in the setup. It works ok, the geometry of it makes it less efficient in my opinion than a frame mount plow such as the Kubota version on the quick hitch. The lift capacity of the smaller tractors makes it difficult to hook a plow up to the loader that allows float and articulation with the ground (loader doesn't dip left or right). That setup puts the plow further out in front of the loader, reducing capacity.
They are impressive little tractors, but their limits can be found easily.
And as far as counterweight is concerned - I have the Kubota rear ballast filled and a couple of concrete blocks on top of it, and the tires filled.... And I still feel a little light in the rear with a good lift. Have even lifted a rear tire off the ground with a bucket curl trying to pick away at a snowbank. All things being relative, you're going to want a substantial counterweight for loader work if you aren't filling the tires.
/ b series options #7
Get the dealer to weld some utility hooks on the bucket. They are indispensable.
/ b series options #8
any other thoughts?
I have a 2005 B7800.
I did not upgrade to an alternator, but did replace the headlight bulbs with led bulbs and have two forward facing and two rearward facing led floods mounted on my Curtis cab. Light are really bright and have had no issues with the charging system and I still have the original battery since 2005. To remove just my bucket, I just remove two pins. (Have a pinned quick release adapter)
I have a FEL and did not load any of my R4 tires, if I'm doing FEL tasks I either have my RM snow blower, or RM six foot mower, or 7 ft. rear blade mount on my 3 pt.
I chose not to load my tires, so my tractor would be less heavy for mowing
good luck
/ b series options #9
Yes, bucket hooks are a must. I didn't realize until recently that they didn't come standard on all buckets! Dad's BX had one as well as my B2650. A neighbor has a Deere 2520 sans hooks, and I've seen a few at the Kubota dealer recently that also were bare.
They're easy enough to weld on and paint if the dealer wants an arm and a leg for them - but I'd imagine it would be a quick cheap deal as people must ask for it all the time on bare buckets. I'd like to find a place to stick one on a backhoe as well.
/ b series options #10
You can move trailers with one of these. This one is home made but they are very reasonable to buy.
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
KBH Tender (A61307)
KBH Tender (A61307)
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61568)
2016 Volvo VNL T/A...
2020 Kubota SVL75-2 (A60462)
2020 Kubota...
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
