B series and loader valve
   / B series and loader valve #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
I am looking at used bigger B's 7800, 3200, 2630, 3030, did all these come w/ a loader valve? I don't need a FEL now, but later who knows.....
   / B series and loader valve #2
Of those you listed I believe the 3200 is the only one that comes with a loader valve. I think it is available without one as well. Only the new models come with the valve.
if the tractor does not have a loader valve, can you add one?
   / B series and loader valve #5
No, not unless they also had a FEL installed.
Yes - fairly easily. The pump is there, you simply add the plumbing.
Mike
No, I think you overlooked the fact that without the FEL subframe & uprights mounted to the tractor, there's nothing to attach the loader valve to.
The 'simple' plumbing also involves adding the aux block and connections at the front and a tank return line back to the HST. Not terribly difficult, but I wouldn't call it "plug & play" either and extra pieces are involved.
The best way to think of a FEL is as a complete kit, and this is obviously the most comprehensive and cost effective way to purchase the components.
You might be thinking of the 3300SU.
   / B series and loader valve #6
I suppose that, from the original post, the intent of the inquiry concerned adding a FEL at a later point - hence would have structure for physical mounting.
As with any project - simple/difficult meter swings wildly depending on equipment and installer.
Agree that this is the easiest way...
Cheers!
Mike
   / B series and loader valve #7
Ahh... whereas I interpreted it as he wanted to know if those tractors came with an integral loader valve - e.g., like the B3300SU. Himself thinking maybe he wanted to use said valve to control some unspecified other implements now, and a FEL at some later point.
OP might just have to elaborate on his 'intent' for us non-mind-readers, eh?
:drink:
To elaborate....if I am looking at a used B7800 that did not come with a FEL, is it possible and how hard would it be to put one on.....I hope this makes sense...I would need a hay bale spear more than I would a FEL probaly...
   / B series and loader valve #9
Well that model comes with one too but so does the 2x20 series and the 3200. I believe the 2320 and 3200 can be had without one but I doubt you see many that way.
   / B series and loader valve #10
I don't think you will be doing much with round bales and a B7800 using a loader mounted bale spear. if that is a goal. Others will chime in here on that issue.
1067 (A53342)
1067 (A53342)
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
