B series and loader valve
   / B series and loader valve #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
I am looking at used bigger B's 7800, 3200, 2630, 3030, did all these come w/ a loader valve? I don't need a FEL now, but later who knows.....
   / B series and loader valve #2
Of those you listed I believe the 3200 is the only one that comes with a loader valve. I think it is available without one as well. Only the new models come with the valve.
if the tractor does not have a loader valve, can you add one?
   / B series and loader valve #5
No, not unless they also had a FEL installed.
Yes - fairly easily. The pump is there, you simply add the plumbing.
Mike
No, I think you overlooked the fact that without the FEL subframe & uprights mounted to the tractor, there's nothing to attach the loader valve to.
The 'simple' plumbing also involves adding the aux block and connections at the front and a tank return line back to the HST. Not terribly difficult, but I wouldn't call it "plug & play" either and extra pieces are involved.
The best way to think of a FEL is as a complete kit, and this is obviously the most comprehensive and cost effective way to purchase the components.
You might be thinking of the 3300SU.
   / B series and loader valve #6
I suppose that, from the original post, the intent of the inquiry concerned adding a FEL at a later point - hence would have structure for physical mounting.
As with any project - simple/difficult meter swings wildly depending on equipment and installer.
Agree that this is the easiest way...
Cheers!
Mike
   / B series and loader valve #7
Ahh... whereas I interpreted it as he wanted to know if those tractors came with an integral loader valve - e.g., like the B3300SU. Himself thinking maybe he wanted to use said valve to control some unspecified other implements now, and a FEL at some later point.
OP might just have to elaborate on his 'intent' for us non-mind-readers, eh?
:drink:
To elaborate....if I am looking at a used B7800 that did not come with a FEL, is it possible and how hard would it be to put one on.....I hope this makes sense...I would need a hay bale spear more than I would a FEL probaly...
   / B series and loader valve #9
Well that model comes with one too but so does the 2x20 series and the 3200. I believe the 2320 and 3200 can be had without one but I doubt you see many that way.
   / B series and loader valve #10
I don't think you will be doing much with round bales and a B7800 using a loader mounted bale spear. if that is a goal. Others will chime in here on that issue.
2016 VOLVO VNL SLEEPER (A54313)
2016 VOLVO VNL...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
Test Button (A47477)
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A55218)
1992 Talbert 70...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
