B-7500 Oil Fliter
/ B-7500 Oil Fliter #1
Trvler
McDonough, Georgia
Kubota B-7500, LA302FL, RCK60-24D, Box scraper
Recently it came time for the first oil change on my 7500. The dealer could not furnish the correct filter. The number that Kubota had furnished were wrong. After a great deal of trouble I came to find out that the correct filter is the same as is found on a 1999 Isuzu Rodeo with the 3.2 litre V-6. I checked with Kubota and found that it cross references to the correct Kubota filter. This filter can be found within most manufacturers lines. I post this in the event any of you have similar problems.
/ B-7500 Oil Fliter #2
Interesting. I was wondering if the new oil filter measure the same as the one on your Kubota also fit well?
I would have try another dealer for the right oil filter,more so with a new tractor...but thats me and I'm very seldom right. /w3tcompact/icons/laugh.gif
I hope you are enjoying your new Kubota,and by the sounds you have spent some time on it./w3tcompact/icons/wink.gif
Take care and be good to yourself./w3tcompact/icons/wink.gif
Thomas..NH
/ B-7500 Oil Fliter #3
Thomas,
I'm with you, why in the world couldn't a KUBOTA dealer furnish a filter or number for a new tractor?????
As posted elsewhere, just because a filter fits doesn't mean it fits!! The tractor may operate under more or less pressure than the car that the filter was spec'd for. What size particles will the car filter take out? The filter was made for a gasoline car engine, you have a diesel tractor engine...WHY take a chance on your new purchase?? /w3tcompact/icons/shocked.gif
JimBinMI
We boys and our toys!
/ B-7500 Oil Fliter #4
Re: B-7500 Oil Fliter..Jim
Jim,
I almost learn the hard way once.
I stopped by another motorcycle dealership in stead of my regular dealer and purchase oil fitler for my Harley Davidson Wide Glide.
The dealer said this would do and there wouldn't be a problem....WRONG/w3tcompact/icons/frown.gif
After changing the oil and installing the new filter than starting up, the oil light wouldn't go off and the rear cylinder gauage show low oil pressure...yikes. /w3tcompact/icons/frown.gif
While purchasing the right filter from my regular dealer he said " just because the filter fit doesn't mean its doing its job for what it was design for" and that I was lucky,and yes I learn a lesson also was a tad/w3tcompact/icons/mad.gif/w3tcompact/icons/tongue.gif at the other dealer and I should have known better.
Motorcycles,cars,tractors etc... there a reason why the manual spec call for the right replacement parts.
If anybody should have doubt double check with another dealer,or one might be shelling out $$$ /w3tcompact/icons/frown.gif
Hope you are enjoying the first day of summer./w3tcompact/icons/cool.gif
Thomas..NH
/ B-7500 Oil Fliter
Allow me to clarify the statement. Due to the 7500 being such a new model, the dealer could not locate the proper part numbers for the oil filter, or so he stated. He did have some literature on hand, but the filters that the KUBOTA literature suggested was incorrect. Aftera great deal of effort a filter that woruld fit was located, and after speaking with KUBOTA it was confirmed that that filter was indeed the correct one. It was not the KUBOTA brand however. NOW... as for filters, I do not usually give recommendations but being that I own a trucking company and therefore own a fleet of Trucks, and yes Diesel powered trucks. And these trucks are powered by engines that produce up to 500 HP, and replacement costs for just the block alone of a Detroit 60 series is around 10,000.00 if not covered under warranty. I have made it a point to become somewhat of an authority on maintenance requirements for the equipment that I am responsible for. I looked carefully at the requiremtns of the little 21 HP diesel in my Kubota and spoke at length about it with a representative of Mobile oil, and I spoke at length about the filters with Kubota. Believe me when I say, "it's correct", then it is correct. The research has been completed at that stage. I am not only a customer of Kubota, they are a customer of mine. We pick up loads in Suwannee GA and Gainesville GA on a regular basis. I am in constant contact with their people at both plants, people at the floor level on up to management. I even took part in a redesign of packaging at the Gainesville plant after two crates collapsed during a haul. See photo. We are picking up a load bound for New Hampshire and Vermont as I type.
/ B-7500 Oil Fliter #6
Trvler,
Congratulations on getting some good reliable data out of Kubota.
If you ever get the chance, please ask this question that was posted in Oils and Lubricants:
After paying $110 for a complete workshop manual for the M6800S, I noticed that one of the difference in the workshop manual supplement (but not in the owners manual) was that Only Super UDT was shown for transmission oil - and it said it came from the factory with Super UDT. Since I just unloaded 17 1/2 gallons of Kubota UDT tonight, I kinda wished I had seen that before now.
The local dealer does NOT use Super UDT in any Kubota tractors unless the customer specifically requires it. They do not use it in any of their rental tractors either and DO NOT even stock it in the store, but will order it. (I live in North Texas and it does not get very cold here.)
What is the big mystery associated with Super UDT? Has anyone else noticed this in the 2000 year model tractors? Is UDT still just as good in a gear tractor and front axle as it was last year?
/ B-7500 Oil Fliter
That is a very good question. At this time I have no idea. I will print your question forward it to several individuals and see if the replys differ. Hopefully I can have a definite answer soon.
/ B-7500 Oil Fliter #8
Thanks and you might also ask the question that continues to plague all of us. Is Super UDT 100% synthetic or a synthetic blend or not any synthetic. A previous post quoted Kubota as stating that it was 100% synthetic, but no one has been able to confirm this. Thanks again - you will be the most welcome contributor on the oil and lubrication topics! /w3tcompact/icons/smile.gif
/ B-7500 Oil Fliter #9
Trvler,
That's a whole lot of work to do, on YOUR part, for a filter for a new tractor! I must say that I enjoyed walking into my NEW HOLLAND dealer and receiving the filters that were made for it. /w3tcompact/icons/cool.gif
I'm sure that you feel comfortable using the filter after doing all the checking yourself, as a novice, I still think that it's really weird that a V6 gas engine would use the same filter as a 21hp Kubota diesel! /w3tcompact/icons/shocked.gif
Good Luck, JimBinMI
/ B-7500 Oil Fliter #10
Jim, lets see....
They both are Internal Combustion engines. They both use a pressure type oil system. Why would you question that they use the same filter? Filters aren't exactly rocket science. You have a filter media and a bypass valve that lets you circulate oil WITHOUT any filtering when the filter gets stopped up.
Wish I had as good connections in the tractor business as Trvler has and maybe some of these endless debates would end with a few simple well articulated facts. /w3tcompact/icons/smile.gif
/ B-7500 Oil Fliter #11
Wen,
In my last response I didn't question that they use the same filter, I thought it was surprising! That they both work at the same pressure and all. If it bypasses because there's not enough pressure then what work is it doing?
Wen, if it's not rocket science, then why hasn't someone designed a one size fits all? Does Kubota have just one filter with specs that fit all engines?
It is OK to question authority once in awhile! Really!
JimBinMI
/ B-7500 Oil Fliter
I've asked a few people about the differences between UDT and Super UDT. As of this moment the only thing that has been unanimous is that Super UDT is formulated with extra additives and is blended for severe duty and / or extreme cold weather. I received very little actual information beyond this point. This has me very curious now. I plan on pursuing this even further. I wish to know who makes the lubrication products for Kubota. More often than not a OEM item such as this is produced by a large and well known company. I'm guessing either Exxon/Mobil, or possibly BP/Amoco. I'll give you an example of something I happened upon a few years back. A refinery in West Memphis Arkansas which is owned by Coastal Unilube processess and packages oil for several oil companies. I saw one case where they produced Chevron and Castrol products as well as their own line.
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
2017 Ram 5500 Bucket Truck (A63118)
2017 Ram 5500...
2022 C&W Gooseneck Trailer (A64047)
2022 C&W Gooseneck...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
1043 (A60430)
1043 (A60430)
