B 7100 HST PTO shift lock
/ B 7100 HST PTO shift lock #1
860thomasb
Connecticut
198? Kubota B7100 hst d
I'm using the rear PTO on my tractor for the first time drilling post holes with a lienbach PHD. The PTO shifter gets locked up and will not disengage. I have been able to disengage the PTO by shutting down the engine(but that doesn't always work), Putting the tractor in gear and moving forward and backward, ( again doesn't always work). My question is: is this common or should I expect the problem will get worse until the pto will not disengage at all?
/ B 7100 HST PTO shift lock #3
Does it do this only with the PHD on or will it also act this way when there is implement attached to the PTO?
Egon
/ B 7100 HST PTO shift lock #4
Egon
Hi EGON, This is the first time I've actually used the PTO. I tested it a couple of times with nothing attached and it worked fine shifting between rear to neutral and mid/rear combo to neutral.
/ B 7100 HST PTO shift lock #7
Sounds like all will be okay. Maybe with the attachment on the gears have to be moved slightly before it engages smoothly. /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
/ B 7100 HST PTO shift lock #8
/ B 7100 HST PTO shift lock #9
On my B7300 the PTO lever slides easily from the engaged position unless there is a heavy load on it. I presume you are depressing the clutch when trying to release it? I often slide mine from engaged to neutral when using my brush hog, and as long as the blades are completely unloaded I don't need to use my clutch. But if they aren't, I get some resistance (and then use the clutch).
/ B 7100 HST PTO shift lock #10
2011 Hyundai Santa Fe SUV (A61574)
2011 Hyundai Santa...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
Keho Super-Flow Grain Bin Fan (A64119)
Keho Super-Flow...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
(2) 25X10.00-12 TIRES W/ 4 LUG RIMS (A64280)
(2) 25X10.00-12...
